| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User Forum Geek | I only own one solid carbide spiral bit. It's also my only Whiteside bit. I need to get more. MLCS has a set that includes,1/4",3/8",and 1/2" for $50. I know I should'nt be afraid of MLCS as I have several of there other bits. But that price is close to what everyone else gets for 1 bit. Does anyone have these? Is there a big difference in the carbide? http://www.mlcswoodworking.com/shops...ter_set_anchor
__________________ Rusty If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi Rusty You know me I have 3 sets,,, they are good bits, and they are MICRO-GRAIN CARBIDE I'm not sure how they can sell them so cheap but they do ![]() I did break one of the 3/8" bits but it was my error and not the bit... ![]() I was putting in a drop and slot in 1" thick ploy. and I wanted to make just one more pass to clean it up and SNAP the bit was junk, the poly. will leave little filbers behind after the cut and it wrap around/jamed the bit in the slot. and broke right off..I should know better... ![]() =========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-17-2007 at 08:07 PM. | |
| | #3 |
| Retired Moderator Supreme Forum King | I need to get some other spirals and going to give MLCS a try on those. I have only used 1/4 inch to date and they are Whiteside bits. corey
| | #4 |
| Registered User Forum Fanatic | I have both upcut and downcut spiral bits from MLCS, and when used properly have worked very well. I did have a 3.97 mm (5/32 in) upcut bit break but that was due to a collet that fails to hold a bit. That router is now retired. I am quite happy with the MLCS bits and use them as often as I use any bits. |
| | #5 |
| Registered User Forum Geek | Hi, Rusty: I have had some MLCS bits and they were pretty good for the money. I now buy a bits from Infinity tools, the carbide is larger and also Micro-Grain. If you use a bit very often then invest more into it. I would buy based on usage of it and my wallet at the time. Hope this helps.. Woodnut65 |
| | #6 |
| Banned Supreme Forum King | I got a MLCS set some time ago, for more $$ because they were not on sale. They have a better BUY now! They're On Sale... IMHO, it's a good time to get them! You will be happy with them! ![]() |
| Cmt 1/4 spiral bits | rich1 | Table-mounted Routing | 1 | 02-29-2008 03:02 PM |
| MLCS spiral bits | rich1 | General Routing | 3 | 02-15-2008 09:09 PM |
| Spiral Bits | fibertech | General Routing | 8 | 04-19-2006 12:06 PM |
| Spiral bits? | archer_456 | General Routing | 6 | 04-11-2005 11:31 PM |
| Spiral Bits | ejant | General Routing | 4 | 02-09-2005 08:15 PM |
