| | #1 |
| Registered User Dedicated Member | does anyone know of a good deal on a t-slot cutter for 1/4" shank thats for 1/4 20, i believe the size is 9/16" please correct me if im wrong. 9/16" 3/8" 1/4" 1/8" 5/16" ![]() |
| | #2 |
| Forum Contributer Supreme Forum King | Hi delirous26 They make many sizes ,The one I like to use is the Key hole bit,,, in that way use can use the standard 1/4-20 Sq. Nuts that just slide in the slot just right, and they are cheap by the box... ======== http://www.mlcswoodworking.com/shops.../bt_keyhl.html
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #3 |
| Registered User Dedicated Member | http://www.leevalley.com/wood/page.a...168,46176&ap=1 what do you think of this one. |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi delirous26 It's OK, but it locks you into using the standard tee-slot nuts at .27 cents each..if not more and the Sq.nuts are about .02 cents ea. not to about the tee-slot screws/fastners,,, I buy the sandard toggle bolts (4" long) that are full threaded and grind the head on both sides and then cut them down to what ever size I need to use.. Just a note**** Tee-Nuts work well also ,once you clip off the sharp points on the t-nuts and grind them with 2 flat spots on the side of the nut washer flange....so they can slide into the tee-slot.. They are about .o6 cents each... ============= Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 09-05-2007 at 12:35 AM. | |
| Router speed for a slot cutter? | Nickbee | Router Bits - Types and Usage | 2 | 12-07-2007 11:13 AM |
| Need help with a slot cutter set up | Nickbee | Router Bits - Types and Usage | 1 | 11-26-2007 03:44 PM |
| Slot Cutter or Spline cutter | kimbert | General Routing | 3 | 10-20-2005 06:26 PM |
| slot cutter jig | knuttle | Jigs and Fixtures | 1 | 12-19-2004 07:04 AM |
| Where to find twin 3/16" slot cutter. | Al Miller | Tools and Woodworking | 5 | 11-17-2004 07:05 PM |
