| | #1 |
| Registered User Dedicated Member | It looks pretty nice and seems to make a good joint. Do they come in different sizes or can one size be used for different widths of wood. Any information is appreciated. (as always) |
| | #2 |
| Senior Moderator Supreme Forum King | One bit will work with 1/2" and 3/4", just less material on the inside of the lock joint for 1/2". Neat idea isnt it? Mike |
| | #3 |
| Registered User New Member | I've used my CMT baby lockmiter on a number of projects. It will make a lock miter from 1/2 to 3/4 inch thick material. There are several things I've learned about this bit set. Setup is critical and the hardest piece to cut is always the one machined vertically against the fence. 1. For the setup. the height of the bit and fence depth is crucial. To get it right, see John Lucas's tips under the A/B method for the lockmiter set at www.woodshopdemos.com. This is a simple and reliable method to produce a tight joint. 2. The router speed needs to be set just a bit higher than what is normally recommended for the diameter of the bit. I've experience cleaner cuts upping the speed just a bit higher. 3. For taller pieces (in width) than your router table fence is in height, a tall fence is really, really nice for holding the piece square. 4. A feather board holding the operation square when upright against the fence is critical. I get good results with this method for plywood and softer woods, but I'm still working on my technique with hardwoods. |
| | #4 |
| Registered User Dedicated Member | Awesome, Thanks, this helps me know what to expect. |
| | #5 |
| Registered User New Member | You are welcome! The bit set does a really nice job, except for end grain in hardwoods. The straw like nature of end grain, in oak especially has some challenges I haven't mastered yet. I think for my setup on my router table it will be in making a holding jig running the upright operation. Now, having used the bit set, and where accuracy can be hidden, I've come to like table saw rips at 45 degrees, followed by my bisket joiner as a faster alternative. But the lock miter is definately a stronger looking joint. |
| | #6 |
| Registered User New Member | My problem with control has been with the vertical pieces, particularly for narrow pieces, such as small drawers. I get better cuts, almost no tear out and cleaner cuts by doing the vertical cust on as wide a piece as my router table can handle and then cutting with a table saw after that to the desired width. For example, I made a 25" vertical miter lock cut and then cut the piece into 4" pieces I needed for the drawers I was making. Since I am using plywood, having the extra 1" at the end took care of any end tear out. The bigger piece was much easier to control for a good cut. |
| | #7 |
| Registered User New Member | I have used the 45 degre locking miter for a couple of years now (just finished a job 2 days ago) and you can't beat it for strength and looks good as well. A tip to make good clean cuts, both vertical and flat on the table: Once you have the bit and fence set, take a 1/8" piece of plywood and double face tape it to the vertical of your fence, this keeps the pieces 1/8" away from their final cuts. Cut all your pieces and then remove the 1/8" plywood and recut all the pieces to their final cut. I agree, good feather boards are a must...
__________________ Dale Fleury |
| 45 Degree Lock Miter bit | mjeisenbaugh | Router Bits - Types and Usage | 6 | 03-28-2008 07:09 AM |
| T-Track vs. Miter Channel | Paul3624 | Table-mounted Routing | 7 | 01-23-2008 12:30 PM |
| Lock Miter Bits | Don Hurley | Router Bits - Types and Usage | 3 | 03-06-2007 12:50 PM |
| Intro | ve1bvd | Introductions | 9 | 02-08-2007 09:02 PM |
| Lock miter bit | Drick | General Routing | 10 | 12-28-2005 09:54 AM |
