Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 09-11-2007, 08:28 PM   #1
tshaw47
tshaw47 is on a distinguished road
Default bit for Jack Miter molding joint
found a molding joint I would like to try. The advantage is that the miter is less likely to open in winter. I understand the Jig construction but can't find a bit that seems to work.
My assumption is a 45 degree champher. Like a v groove but with an end mill if that makes sense. A top bearing for a guide in the template. Unable to attach the Jack miter article link, but I did attach a picture of the cut. The author mentions grinding the bottom of the bit flat, but I would prefer an engineered solution.
I appreciate any suggestions.
tshaw47 is offline   Top - Reply with Quote
Old 09-11-2007, 08:54 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I appreciate what you are trying to do, but I think a reminder of how wood moves might be in order. Wood fibers are very much like a bundle of straws. Moisture enters through the ends very easily, but most of the movement is cross grain as it expands or contracts. You should see very little difference in length. I use angle cuts on molding but I do the cuts with a small flush cut saw with fine teeth or in my miter saw. I really think there is little advantage to this particular cut in the photo. Even so, the answer to your problem is you can buy bearings to fit on the shank of your router bits, they are even inexpensive. I have never seen a bottoming chamfer bit but I imagine one of the companies makes them. You might look at the MLCS web site or perhaps Eagle America offers them.
Old 09-11-2007, 08:56 PM   #3
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
W e l c o m e . . A b o a r d !!
Joe Lyddon is offline   Top - Reply with Quote
Old 09-11-2007, 09:01 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
This may help
But the bit will be hard one to find..
http://www.metacafe.com/watch/797840...he_jack_miter/
http://forums.jlconline.com/forums/s...32&mode=linear
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Locking Miter George II General Routing 3 02-18-2008 08:05 PM
T-Track vs. Miter Channel Paul3624 Table-mounted Routing 7 01-23-2008 01:30 PM
Incra half blind joint S Bolton Jigs and Fixtures 7 10-23-2007 02:38 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 09:52 AM
miter gauge for table saw, help delroy33 Tools and Woodworking 3 10-27-2004 05:01 PM
