| | #1 |
| Registered User Jr. Member | While cutting a Dovetail on the table router, the bit loosened and raised while making the male cuts. It seems that there is upward pressure that raises the bit. I tightened it hard and still it raised. The shank is 1/4" and 9' . I'm making a sliding door lock.
__________________ [color=DarkGreen][size=7][font=Verdana] |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi Ken Dovetail bits do like to climb up hill,, are you sure it's the bit and not the router motor moving up.. Not all bits are made the same,some are under size....get your mike out and check the size of the shank....it should be .246 to .251 any thing other than that and the bit will not clamp down in place...or stay in place... Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ | |
| | #3 |
| Registered User Jr. Member | Thanks BJ, The shank is undersized. I'll get a new bit and try again.
| | #4 |
| Forum Contributer Supreme Forum King | You'er Welcome Ken After you get a new bit ,Pls. repost and tell us how it works now ![]() =============
| Dovetail jig | TomHerb | Starting Off | 1 | 06-28-2008 10:48 AM |
| Keller Dovetail Jig bits-Where/How do I replace them? With what? | nicksorenson | Router Bits - Types and Usage | 7 | 06-08-2008 01:01 AM |
| Dovetail Depth of Cut | Sherwood | Portable Routing | 5 | 09-15-2007 10:28 AM |
| New Lower Priced Leigh Dovetail Jig | scrollwolf | Jigs and Fixtures | 1 | 07-08-2007 05:10 PM |
| dovetail spline joints | reible | Jigs and Fixtures | 7 | 10-02-2004 01:50 PM |
