Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - Minimum HP required for raised panels.
Thread Tools Display Modes
Old 09-21-2007, 06:45 PM   #1
traveler
New Member
traveler is on a distinguished road
Default Minimum HP required for raised panels
Is it possible to do raised panels with a 1 3/4 HP Porter Cable Router, or is it pretty much a futile effort? I have a speed control.
traveler is offline   Top - Reply with Quote
Old 09-21-2007, 07:10 PM   #2
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
W e l c o m e . . back, after awhile.
It may be possible but I think you would be happier with a router closer to 3HP... maybe some of the 2+'s would also work... The higher power with those huge bits is definitely a big plus.
Now, if you were using a horizontal router table, using the smaller diameter bits, that's another story... I don't know.
Joe Lyddon is offline   Top - Reply with Quote
Old 09-21-2007, 07:11 PM   #3
Hamlin
Supreme Forum King
I would think that you have plenty of power. It is the speed that is crucial, larger bits= slower speeds. Others here may have a better answer than I.
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 09-21-2007, 07:14 PM   #4
AxlMyk
Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
You'll have to take off SMALL amounts at a time..
AxlMyk is online now   Top - Reply with Quote
Old 09-21-2007, 07:29 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI traveler
It will do it but you will need to have a speed control device on the router or a speed control box for it, But you are best off to use Vert.router bits like the ones in the link below..
Then you don't need to buy a speed control box if you don't have one ..or use you speed control device on the router...most 1 3/4 routers don't come with them.
You will be be taxing the router to the max with the standard panel bits and you will need to make many cuts to get the job done..
http://www.mlcswoodworking.com/shops.../raisvert.html
bobj3 is online now   Top - Reply with Quote
Old 09-21-2007, 08:10 PM   #6
traveler
New Member
Thanks for the advice. I recently took a woodworking class where we also had to take a small amount at a time. I do have a speed control box.
Old 09-21-2007, 08:22 PM   #7
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
If you just have to do one set and not a bunch of doors to do... a one off project then it's not worth getting a bigger router in my opinion. If your multiple doors then it's time to consider a bigger router. As others have said, tiny bites and a speed control is the answer. I have never done raised panels but I have done rail and stiles with a speed controller with a 1 1/2 HP router.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 09-21-2007, 09:11 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi traveler
Just a note ,,, you don't need to use the BIG panel cutters 3 1/2" ones they do make some that are 2 1/2" dia. that will make it a bit easyer on your router.
Old 09-22-2007, 05:55 PM   #9
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
You can also make the panels with a table saw, and just use the router for the rails and stiles.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is online now   Top - Reply with Quote
Old 09-22-2007, 06:00 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi traveler
"panels with a table saw"
I have made a jig to do just that on the table saw.
If you want to see a snapshot of it just ask and I will post one or two..
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 3 02-13-2008 07:59 PM
Question about raised panels tpyke General Routing 4 01-29-2008 01:40 PM
Router for raised panels Jtomwoods Table-mounted Routing 3 08-21-2006 12:59 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
Raised panels CanuckBeaver Tools and Woodworking 3 10-20-2005 12:27 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
