| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #11 |
| Forum Contributer Supreme Forum King | Hi Cowboy You use 1/8" plywood ? I can see 1/4" thick plywood but it's only about 3/16" thick,,but 1/8" plywood ??? , or are you saying 1/8" hardboard , I will need to check that one out ![]() =========
| | #12 |
| Forum Moderator Supreme Forum King | That's alright Bj I don't use plywood for my sides or tops unless I'm making panel sides. I use only 1" or 3/4" stock anyway so it is a good sugestion from Joe and Cowboy.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| | #13 |
| Registered User Supreme Forum King | Ok, now I'm confused. I understand the T&G, because I use them myself. I'm not quite understanding the 1/8 ply suggestion. Why create an extra step? It's been a very long day here, so, it could just be me not seeing the bigger picture.
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #14 | |
| Forum Contributer Supreme Forum King | Hi Glenmore Now I'm confused ,, didn't Cowboy say he use the very thin 1/8" plywood for splines..? to join two or more boards as one.. ========= Quote:
| | #15 |
| Forum Moderator Supreme Forum King | What did Mark put in the watering hole? Now everyone is running around confused ![]()
__________________ Cheers, Bob |
| | #16 | |
| Retired Moderator Supreme Forum King | Quote:
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #17 | |
| Registered User Forum Geek | Quote:
- but - to clarify Yes - I did say that - and yes -- I have done that Only done it a few times - but with excellent results. And - it very well may have been some scrap hardboard I had on hand - rather than plywood. It's been a while. I don't remember where I got the idea - but I did it once out of curiosity - and other times because it worked and it was fast and simple. Essentially the boards were edge-glued the spline was just there to help with alignment and add a little extra glue surface. Yes - If you are looking for added support making two passes with the table saw - thus getting 1/4" would be stronger. Everybody's projects are different - What few glue-ups I need to do are usually either either tops or sides for a chest or bookcase. There are always shelves or drawer frames or other cross pieces to take care of support. MOST of the time -- I get by fine with simple edge gluing -- no slots - no splines. If I were doing larger areas or areas subject to more stress - my choices would probably be different. Hamlin - I like tongue and groove The spline method was just faster -- for me at the time. I could make all the cuts on my table saw - without adjusting the height and moving the fence only once. If anybody has read more more than one of my posts - you KNOW I am NOT saying this is the only way -- or even the best way -- just that it is a quick and simple way - that DOES work for some projects. Confusion resolved?? I hope ![]()
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. Last edited by Drugstore Cowboy; 10-22-2007 at 07:09 PM. | |
| | #18 | |
| | #19 | |
And I am about due for a new blade - - - - hmmmm ![]()
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. | |
| | #20 |
| Forum Moderator Supreme Forum King | Sorry guys I miss read so I'm the cause for the confusion. Well at least you guys on your toes. I'm just out there. hahaha
| Glue and Bits? | Noddy | General Routing | 7 | 10-16-2007 10:18 PM |
| Magnate Router bits | kp91 | Tool Reviews | 2 | 07-09-2007 04:36 AM |
| Need help deciding on bits. | ryan.s | General Routing | 8 | 03-25-2005 10:35 PM |
| router bits from oak park | reds_21 | General Routing | 1 | 02-09-2005 01:59 PM |
| another sorry question about router bits | reds_21 | General Routing | 7 | 12-30-2004 05:31 PM |
