Help
Go Back   Router Forums > Routers > Router Bits - Types and Usage
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Glue bits
This is a discussion on Glue bits within the Router Bits - Types and Usage forums, part of the Routers category; Any one here use a glue bit. It is a router bit that gives a ...
Old 10-21-2007, 12:03 PM   #1 (permalink)
Glenmore's Avatar
First Name: Glenmore
Glenmore has a spectacular aura about
Question Glue bits
Report Post Report This Post!
Any one here use a glue bit. It is a router bit that gives a specific groove on each board that would be like a track for gluing. I want to maybe get on. Because I want a tighter seam when I'm making table tops or panels for less wood seam notice.
Glenmore
Mountain Top PA
Glenmore is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 10-21-2007, 12:22 PM   #2 (permalink)
challagan's Avatar
challagan is on a distinguished road
Here is some info and demo from John at Woodshop Demos on this type of bit. I think this is what you were wanting anyway.
http://www.woodshopdemos.com/cmt-gl1.htm
http://iowacarver.tripod.com/
challagan is offline
Old 10-21-2007, 01:20 PM   #3 (permalink)
Glenmore's Avatar
Thanks Corey that is the one. Do you or someone else try this bit. I would like to know if it is worth getting I know they are a little pricey but I do think it is worth it.
Glenmore
Mountain Top PA
Glenmore is offline
Old 10-21-2007, 01:38 PM   #4 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
Hi Glemore
Out of the bits the gliue joint bit is one of the hardest to setup and use..
Next to the lock miter bit, it's also one of the hard ones to use and setup.
If your stock is dead on you have a chance to get it right that's to say if the stock is 3/4" + or -0 it's not to bad, but if it off just a bit it will stick out like a sore thumb and you'er in for alot of sanding...to fix it...the error comes from you need to guess where the center is on the bit.. it's not marked and it's on the center of the male part of the bit...tricky setup..... a real fire wood maker
You may want to take a hard look at the T & G bits,,,it will plane one of the boards at same time it puts the male part for the T & G , many use the biscuits when the T & G bits will do it so much better,,, I like to use the 3/8" wide T & G setup because it's bit stronger, but the 1/4" wide will work just as well
Here's link to a great price for the T & G set...
http://cgi.ebay.com/11pc-1-2-Shank-S...QQcmdZViewItem
You can also get over size bearing from MLCS that fit right on the shank, that will let you put in a 3/16" deep slot, that's nice if you want to make some wider boards out of 1/4" to 1/2" thick stock...
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 10-21-2007, 08:59 PM   #5 (permalink)
kp91's Avatar
First Name: Doug
kp91 is a jewel in the rough
Got one as part of a set from Woodline way back when... more work than anything else. If you have a good edge on your stock, stick a couple of biscuits in for alignment sake and just glue it up.
I did get the quick blocks setup aid for the lock miter, it helps a little, but that thing still is a pain to set up. Not quite as quick and easy as they show at the woodworking demo!
1 John 1:9
Fredericksburg, VA
http://www.usmm.org/postertalk2a.html
http://www.starspangledbannerchallenge.com/
kp91 is offline
Old 10-21-2007, 09:40 PM   #6 (permalink)
harrysin's Avatar
First Name: Harry
harrysin is a splendid one to beholdharrysin is a splendid one to beholdharrysin is a splendid one to behold
Hi Glenmore, it's good to see you feeling better and getting stuck into bigger things than pens. As you would expect, I'm about to put in my 2 cents worth. In my humble opinion, the easiest way to join long boards is with a slot cutter in the table. Set the height approx. half way, it's not at all critical, and run the boards all the way through the slotter. Now cut strips of plywood and glue them in like very long biscuits and the joint will last for at least one hundred years, I know this as I first came across this method when I was given, and dismantled a very old heavy door that was in perfect condition and took a lot of hard work to take apart. the only important thing to bear in mind Glenmore is that the slot cutter must have the same curf as the plywood thickness.
Harry
harrysin is online now
Old 10-21-2007, 11:19 PM   #7 (permalink)
Glenmore's Avatar
Thanks that is a good idea Harry have one of those. So I won't have to get one of them higher class bits.
Glenmore
Mountain Top PA
Glenmore is offline
Sponsored Advertisements. Register to disable this advertisement.
Old 10-22-2007, 11:02 AM   #8 (permalink)
Joe Lyddon's Avatar
First Name: Joe
Joe Lyddon will become famous soon enough
Cool
Glenmore,
A simple way to do it is on the Table Saw with the 1/8" blade kerf...
Get a sheet of 1/8" plywood at a BORG or wherever and just slice off strips with your band saw...
edit: I use plywood due to it's ease of use and STABILITY. /edit
You can use the same principle for drawers, etc.
(That's what I did in building the drawers for my TV Tool Box drawers)
Have Fun,
Joe
Alta Loma, CA
www.WoodworkStuff.net
Joe Lyddon is offline
Old 10-22-2007, 01:00 PM   #9 (permalink)
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
I've used this method a few times very quick and simple.
And as mentioned - a VERY solid joint.
Very clean too -- if your edges are true.
The handy thing about this method (or the slot cutter) is that you dont have to worry so much about being dead center of the board.
Since you are cutting the same x distance from the rip fence (or the router table) on every board - you are guaranteed at least one smooth side. Two assuming your boards are equal thickness.
As a rule
"You can get it quick, cheap, or right - but you can't have all three."
Well -- this is one of those very rare occassions -- where you can
The one who says it can't be done --
Should avoid interrupting
the person doing it.
Drugstore Cowboy is offline
Old 10-22-2007, 01:30 PM   #10 (permalink)
Joe Lyddon's Avatar
First Name: Joe
Cowboy, very good points that I hadn't given much thought... You're SO RIGHT!
... good to see you back and kicking...
Have Fun,
Joe
Alta Loma, CA
Glue and Bits? Noddy General Routing 7 10-16-2007 09:18 PM
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 03:36 AM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
router bits from oak park reds_21 General Routing 1 02-09-2005 12:59 PM
another sorry question about router bits reds_21 General Routing 7 12-30-2004 04:31 PM
