| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User Forum Geek | Ok so here’s a stupid question… I have this table: ![]() I’d like to fit a t-track in the miter slot (I think that’s what it’s called) but the grove (dado) is ¾” x ¼’. Is there a guided bit out there that I could make this thing ½” deep to accept a standard T track? Or am I stuck using a standard dado bit and rigging up a straight edge as a guide? Thanks! |
| | #2 |
| Registered User Forum Fanatic | I don't think you'll find a bit that will follow the existing groove without cutting too deep for what you need. Probably better to clamp a straight guide to the table along the edge of the groove and follow that with a top bearing mortise or flush trim bit. The Freud 16-520 is 3/8" carbide height and 3/4" diameter so it would work in that scenario. |
| | #3 | |
| Registered User Forum Geek | Quote:
Sit it in your existing groove with the cutter against the edge. Then clamp your straight guide against your router base. Check both ends to be sure your guide and groove are parallel. Just an option - if you don't already have a flush trim bit and want to get it done quick. Charles' way makes positioning your guide easier since you are following an existing line. And if you dont already have a flush trim bit -- it gives you a good excuse to go buy one. It's a pretty simple process either way -- not that much different than if you were cutting the dado from scratch -- and making multiple passes.
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. Last edited by Drugstore Cowboy; 11-14-2007 at 09:35 AM. | |
| | #4 |
| Registered User Forum Geek | I have this bit and it is short enough to do what you need. It also leaves a very clean flat bottom cut as a dado clean out bit should. http://www.mlcswoodworking.com/shops...s/bt_dado.html
__________________ Rusty If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It |
| | #5 | |
I had read about those a while back and had meant to buy one but got involved in other things. Totally forgot aoout it. I occassionally cut through dados on table saw (multiple passes - not a dado blade) or with multiple passes with a small bit --- Something like that that would require no special setup to make the final pass -- both to fine tune my depth and smooth the bottom at the same time - - would be great. ![]()
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. | |
| | #6 |
| Forum Contributer Supreme Forum King |
| | #7 | |
The channel that's there now should guide the bit nicely. Here's a stupid question. When doing something like this should it be done with multiple passes to put less strain on the bit and router? I have to have the dado 1/4 deeper than it is now. THANKS AGAIN! | |
| | #8 |
| Registered User Supreme Forum King | If all you are taking out is a 1/4" you will be fine. If over that, several passes.
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| Router Table Dado Jig | RoyBullets | Jigs and Fixtures | 11 | 06-16-2008 09:41 PM |
| Making a vase part 1 | chippypah | Woodturning and Lathes | 0 | 03-04-2008 03:23 AM |
| Inserting a dado at a set distance from the edge of a curved surface | Woodentop | General Routing | 4 | 11-20-2005 06:05 AM |
| Router Adjustable Dado Jig | Barry_White | Jigs and Fixtures | 4 | 02-07-2005 02:17 AM |
