Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 12-02-2007, 04:02 PM   #11
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I have to disagree with BJ about the Bosch guides. They are intended for heavy duty construction use and they perform just fine. Home woodworkers are not nearly as likely to damage a guide bushing since there is little travel and transportation damage. The PC adaptor works like a champ with it's quick release. A good thing to consider before purchase of a sub base plate is if you want to use the larger Router Workshop style guide bushings. They allow for more combinations than the PC style. People on a tight budget may not want to invest in two sets of guide bushings. There is always the option of getting the more common (and less expensive) PC style and adding only the larger Router Workshop style so there is no duplication. Another HF item worth serious consideration is their version of the Rousseau mounting plate. At a price of $20 it can not be beat. This allows the use of the Rousseau mounting template and centering kits for super fast and accurate installations.
Remember there is no wrong choice in your routing set up. Go with which ever one feels best to you.
Spiral Bits/splinters George II General Routing 5 01-29-2008 11:50 AM
Spiral up or spiral down slumlord Introductions 6 12-14-2007 01:54 AM
spiral bit woodendigits General Routing 2 09-04-2006 12:15 AM
Table Top Material rh111 Table-mounted Routing 4 04-19-2005 04:35 AM
Bit problem - using spiral bit in a table Matt General Routing 4 11-23-2004 09:02 PM
