| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User New Member | Howdy, Is there a glue joint router bit that doesn't require a router table? TIA |
| | #2 |
| Marine Engineer Forum King | In my humble opinion, glue joint bits should only be used in a table. That being said, you can make a simple table out of just about anything. It can be as simple as a piece of MDF on 2 saw horses, or anything else you can find. I bet if you start using one in a table, you'll soon find yourself looking for plans....... here's an idea someone shared just this week: http://www.routerforums.com/introduc...hanks-all.html
| | #3 |
| Forum Contributer Supreme Forum King | Whilst I personally believe that the majority of routing can, and probably should be done hand held, there are operations, and as Doug has said, this is one that should be done in the table, and if space is what's stopping you from making a table, then the one shown in the link that Doug posted would be the way to go.
__________________ Harry |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi aurgathor I will 2nd. what Doug said, the glue joint bit is one of the hardest bits to setup and use, it takes a table and a offset on the out feed end of the fence. The router bits needs to do two jobs in one pass, it puts in the joint and it also works like a jointer...putting on a nice clean/sharp edge ..so you can't see the joint at glue up time...no bearing on the type of bit that's why you need a router table fence to keep it true all the way down the edge of the stock... =========== How to setup the bit and use it http://www.woodshopdemos.com/cmt-gl1.htm info about the bit ▼ http://www.mlcswoodworking.com/shops.../instruct.html ============== Here's a tool you can buy that makes it a bit easyer to setup the bit and other bits as well... ROUTER SET UP JIG http://www.sommerfeldtools.com/item.asp?n=EZSET&f=1 I should note I have one of the EZset up tools, it works best on the CMT bits it will work on other makers of bits but not all bits are made the same way. ============== here's just two more router tables that are easy to make.. see two PDF files below ============ Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 12-03-2007 at 11:33 AM. | |
| | #5 |
| Registered User Forum Fanatic | The diameter of most glue joint bits allows for their use in hand held operations with the use of an edge guide or fence (as Bj noted they are not bearing guided). So it could be done if you use a guide, guards and take the proper safety precautions but you would not be happy with the results. Save the wood you would have wasted and build a router table. |
| | #6 |
| Registered User New Member | I do have a router table, however, the piece I want to work on it is 5'x10', and I don't have enough space for that. Unless I slide the router table on that piece of wood, but I'm not very comfortable with that. |
| | #7 |
| Registered User Forum Fanatic | What's the application? Maybe there's another way to skin this cat. |
| | #8 | |
| Forum Contributer Supreme Forum King | Hi aurgathor Is that 5 foot by 10 foot ? If so you'er right it's not a job for the router table , but I would drop the glue bit and use a T & G set with the router edge fence it place for a safe guard... The T & G sets come with bearing that will ride on the edge of the stock and with care it should do the trick .. ======== Quote:
| | #9 | |
| Registered User New Member | Quote:
I was originally thinking of T&G, but thought that glue joint bits are nicer, but if I can't use one.... Last edited by aurgathor; 12-03-2007 at 05:43 PM. | |
| | #10 | |
| Forum Contributer Supreme Forum King | Hi aurgathor You may also want to use a 1/4" wide slot cutter, if the edge on the 5ft x 10ft particle board. is a Fac.edge,it should be square and true so all you would need to do is cut some 1/4" thick birch plywood, 7/8" wide splines and glue and clamp the 5" wide boards in place.. http://www.routerforums.com/attachme...-bisk-jig-.jpg ============ Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 12-03-2007 at 06:56 PM. | |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 11:19 PM |
