Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - Best bit for tight fitting box joints?.
Thread Tools Display Modes
Old 12-04-2007, 09:38 PM   #1
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Default Best bit for tight fitting box joints?
I posted this question in my router ver1.0 (in the table forum) post but figured I would ask here also.
Is there a style and or brand of bit that works best for tight fitting box joints. I just made my 1st box joints with an incra jig and whiteside ¼” spiral up cut bit. The fit is decent but a little loose.
Any suggestions would be great!
Thanks!
Nickbee is offline   Top - Reply with Quote
Old 12-04-2007, 09:45 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
You got as good as bit as any Nick I think. I would look at your movement thru the jig when pushing it or your set up otherwise. Takes some practice from what I have heard. You say they are loose but they look good to me. Friction fit don't work though huh? I wonder if you tried it again with 2 pieces at a time versus all four. I doubt the bit is the reason though. I use the whitesides and have not had that problem with my OP but then again the OP box joint jigs are about the simplest to get a good fit on.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 12-04-2007, 10:04 PM   #3
Nickbee
Forum Geek
Nickbee's Avatar
gotcha. I'll try two at time verses 4 next time. I wonder if there is an "undersized" bit out there just for box joints...
Old 12-04-2007, 10:21 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Nick
Yep,,, Metric , and it comes with a Small hammer LOL LOL
You got it just right , you need some room for the glue right ,,,. the glue will act as a lub.water down the glue just a little bit and use a small brush to coat the parts...the best way I have found is put some glue in a jar lid and mix just a little bit of water with the glue, then brush it on/in the dovetails...
Have a spray bottle of water and white vinegar 50/50 mix ,spray the mix on the joints and wipe with a clean rag...this will remove the over flow of the glue and you will not have the Bloch show up at stain or finish time.
bobj3 is online now   Top - Reply with Quote
Old 12-05-2007, 08:40 AM   #5
Nickbee
Forum Geek
Nickbee's Avatar
yup,, I guess I'll wait till I do a glue up and see how it turns out.
Old 12-05-2007, 12:27 PM   #6
Hamlin
Supreme Forum King
I use OP's spiral bit (upcut), and OP's box jig(s). They are simple to use, if need a tighter fit, as Bob would say, "use that fine adjusting tool".
I know time wise, it's best to do 2-3 at a time. For myself, I simply just do 1 at a time.
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 12-05-2007, 12:46 PM   #7
Nickbee
Forum Geek
Nickbee's Avatar
I watched the incra box cut video again last night. The dude on there mentions that if your bit measures exactly ½”, 3/8”, etc your joint will most likely be slightly loose. Said some bit manufactures purposely machine their bits slightly smaller. Again this joint isn’t horrible, but it would be nice to tighten things up…
Old 12-30-2007, 07:21 PM   #8
Ken D
Jr. Member
Ken D is on a distinguished road
Nic,
Remember the scrap rule. Do a sample of the same kind of wood first. Make any adjustments and test until good.
[color=DarkGreen][size=7][font=Verdana]
Ken D is offline   Top - Reply with Quote
Old 12-30-2007, 07:52 PM   #9
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Accurate set-up and one piece at a time solved all my problems Nick. and as Bj. said, there must be room for the glue. As a matter of interest, I can't see much wrong with you're joints as shown.
Harry
harrysin is online now   Top - Reply with Quote
Old 12-31-2007, 12:13 AM   #10
Nickbee
Forum Geek
Nickbee's Avatar
oh ya the problem has been solved... My 90 deg fixture was not tight enough to the fence (nylon screws had to be adjusted) and I also stop the router after "cutting in" to a piece. I have not tried a box joint again but my dovetails came out great.
Thanks!
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 5 01-21-2008 08:14 AM
Finger Joints J0B00 Jigs and Fixtures 18 08-24-2007 02:19 AM
kreg joints reible Tools and Woodworking 12 04-11-2006 08:36 AM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 10:20 AM
