Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 12-07-2007, 11:48 AM   #1
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Default Router speed for a slot cutter?
I’m going to be using a whiteside 1 7/8” wide slot cutter to attempt a “rail and stile” with poplar 1x2s. Is it safe to use this bit at top speed on my table and Bosch 1617? Or should it be toned down a bit?
Thanks!
Nickbee is offline   Top - Reply with Quote
Old 12-07-2007, 12:07 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Nickbee
From Bob and Rick at the RWS
Router Speeds!
When using a router it involves two speeds,
1) the speed the bit is spinning,
2) the speed at which the material is being fed.
The feed speed should never be greater than the ability of the bit to clear the material being removed.
A good feed speed will produce shavings, too fast does not allow the bit to cut properly and may cause chatter because the chips are not removed properly. Too slow may cause the wood to burn.
Common Router Speeds
1” Diameter Cutter – 24,000 RPM
1 1/4” – 2” Diameter Cutter – 18,000 RPM
2 1/4" - 2 1/2” Diameter Cutter – 16,000 RPM
3” – 3 1/2” Diameter Cutter – 12,000 RPM
http://www.routerworkshop.com/routerbits.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 12-07-2007, 12:13 PM   #3
Nickbee
Forum Geek
Nickbee's Avatar
good stuff! Looks like I should tone the the speed a little for this bit.
Thanks!
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Newbie with an unusual router application wm_brant Introductions 6 10-31-2007 04:16 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
