Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 12-29-2007, 05:24 PM   #1
ed brabham
ed brabham is on a distinguished road
Default porter cable 690 max bit size
Does anyone use a horizontal panel raising bit in this router?What dia have you used?The book said a max of 2.125?
ed brabham is offline   Top - Reply with Quote
Old 12-29-2007, 11:34 PM   #2
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Welcome to the forums Ed.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 12-29-2007, 11:55 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Ed
I do and have used the 3 1/2" bits with the PC 690 but you will need to get a VS control unit to get the speed down..
But if you want to make it a bit easyer on the router you can used the bit listed below..with a easy to make jig you can make panel doors all day long with the PC 690...if you want to see the jig just ask and I will post a link to it.
http://www.sommerfeldtools.com/list.asp?d=71&p=1
http://www.mlcswoodworking.com/shops...ter_bits2.html
here's a link to a VS unit
http://www.harborfreight.com/cpi/cta...emnumber=43060
Some of the 600 PC's come with a built in speed control if that's the case you have it made.
Ed
Here's a link to the easy to make jig
http://www.routerforums.com/jigs-fix...uick-easy.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 12-30-2007, 12:37 AM   #4
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Originally Posted by bobj3
Hi Ed
Ed, welcome to our little corner of the 'net, and thanks for bringing up this question... PC 690 will be my main router, just as soon as I finish the table for it. I would not have thought that 1.75HP would be adequate for large raised panel bits.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 12-30-2007, 09:07 AM   #5
Fourleftpaws
Forum Fanatic
Fourleftpaws's Avatar
First Name: Larry
Fourleftpaws is on a distinguished road
Send a message via Yahoo to Fourleftpaws
Bj - how do you have the VS unit mounted- in the case that you have a table (in-closed) router?
Larry
"Have you hugged your pet today"
Fourleftpaws is offline   Top - Reply with Quote
Old 12-30-2007, 11:59 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Fourleftpaws
I have a power switch mounted on the front of the cabinet on the left side and on the other side (right side) the VS box is mounted just to the inside of the cabinet so I can get to it and select the speed I need to use...the VS box has a switch on that I can set to full power or VS or Off ....plus the router just plugs into the VS box...I also have a 2 gang outlet box on the back side of the cabinet that the router plugs into and the other side of the outlet is for a light or Vac.plugin...
The VS box only controls the router not the outlets,the front switch kills all power to the cabinet...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Porter Cable 690 D handle router S Bolton General Routing 17 09-22-2007 11:28 PM
Anyone use the Porter Cable 7216 Omnijig ??? emailtim Jigs and Fixtures 8 03-28-2006 10:37 AM
6 Bits by Porter Cable AndrewDS General Routing 4 02-13-2006 08:28 PM
Porter Cable router jig table mount Phil Swearingen Jigs and Fixtures 0 11-06-2005 12:19 PM
Adapting Makita sub baeplate for porter cable template guide Arnolds General Routing 3 11-20-2004 06:20 PM
