Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 03-13-2008, 12:54 PM   #1
RuggerJoe
Jr. Member
RuggerJoe is on a distinguished road
Default Flush trim bit not flush
I ordered the 15 bit box set form MLCS and used the flush trim bit for the first time the yesterday. The bit seems a little under sized for the bearing as the bit not cutting the material perfectly flush with the other surface. Its leaving it raised by about 1/32" maybe less. Is this normal? Or should I contact MLCS?
RuggerJoe is offline   Top - Reply with Quote
Old 03-13-2008, 02:08 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
The bearing shoud be dead on.. if it's not make the 800 number call to MLCS and have them replace it....but be sure you are 100% right, take a strait edge and put it on the edge of the cutter , on the bit and it should just touch the edge of the bearing...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-13-2008, 10:14 PM   #3
RuggerJoe
Jr. Member
Well I checked it with a straight edge and it is dead on as far as I can tell. So what am I doing wrong that it didn't cut flush? I was attempting to trim a pine board to lenth across the grain.
Old 03-13-2008, 10:52 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
"across the grain" can be a bit harder to get done, all I can think of is to make more than one pass ,the way the bit is design it will do the job...are you using a template or any part of the router table fence....??
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-14-2008, 08:47 AM   #5
RuggerJoe
Jr. Member
I'm in an apartment so I only have hand tools wish I had the space for a router table and table saw. (I want to build a small/portable router table).
I was cutting two boards for the sides of a box, one ended up being about 1/16 - 1/8 of an inch longer than the other. So I clamped them up side by side to even them up using she shorter of the two as my template. I have to trim down the endes of the other sides of the boxe once I glue it up. I'll give it another try then.
Old 03-14-2008, 05:56 PM   #6
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Always difficult to cut something, especially an 1/16" - 1/8" against the grain. If you have a circular saw and a straight edge, I'd trim it this way instead of trying the flush bit.
You may want to try clamping the pieces on top of each other, ie., the shorter piece on the bottom. But, it's still going to be very difficult to trim being you're cutting against the grain.
Ken
"A VETERAN"
Old 03-14-2008, 06:48 PM   #7
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
No it’s not normal.
But I have been seeing this more frequent past few years and more so these days with number of manufacturers.
Including plywood router bit that are not accurate.
With the exception of handful of manufacturers, over 95% + of the router bits are being manufactured in china the past decade or so and the quality control (not to mention the steel and carbide quality) has been sliding and has hit the new low.
Even Bosch router bits that used to be one of the best back in the 90’s are being made in china now.
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Old 03-15-2008, 11:13 AM   #8
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
Another reason I buy Freud bits. There are others just as good, but I go to Marsh power tools in town and that's what they carry.
AxlMyk is offline   Top - Reply with Quote
Old 03-19-2008, 01:57 PM   #9
RuggerJoe
Jr. Member
I tried the bit again the other day and it did better in the same situation across the end grain. It only left the one piece a hair higher, which was quickly sanded level.
Flush trim bits Hamlin Router Bits - Types and Usage 4 12-01-2007 02:51 PM
Flush trim bits boxer Router Bits - Types and Usage 6 10-31-2007 11:34 AM
Flush Trim Bit? cbsjoez1935 Router Bits - Types and Usage 5 07-28-2007 12:35 PM
Where to get a flush trim bit? wanart Router Bits - Types and Usage 4 10-28-2006 09:39 AM
Flush Trim Bit odamsr General Routing 3 09-14-2005 07:32 AM
