| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User | Need help with setting up to route 3/4 inch stock. |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi f-lhs87 Take a look at the link below it will help ![]() http://www.routerforums.com/project-...ow-videos.html ========== http://www.routerforums.com/69099-post2.html =========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-25-2008 at 12:43 PM. | |
| | #3 |
| Registered User Supreme Forum King | Hi Bob, I have a set of these, never used them... yet. If I'm looking correctly, what exactly is holding the center piece of your fence? I think you've explained this to me once before but, my tired brain has forgotten. I know the purpose of it, chip removal.http://www.routerforums.com/69099-post2.html
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Ken On that fence I like to use the T & G to hold them in place ![]() It's a bit harder to make new ones (replacements ones because they must line up right on the button, so I recommend the 10 deg. back cut that works well for most users...if the main fence as a back support then the T & G works best because they are locked in place.. =================... Quote:
| | #5 |
| Registered User Supreme Forum King | Hi Bob, I think I will add your setup to the new RT fence.... once I get that far. ![]()
| | #6 | |
| Forum Contributer Supreme Forum King | Hi Ken Sounds good, when you make the fence and the inserts make about 10 or 15 of the inserts, you can flip them over and have 30 to select from...some can be used for more than one type of bit but some can't... ![]() But by doing it ths way they will all line up dead on... A real must you don't want them out of line when you make a pass by the bit...also make one that is off set by 1/16" and 1/32" so you can use it like a jointer on the off feed side, again a must when you use bits that don't have bearing on them and they take a bit on the stock away in the pass... They can be a bit tricky to make just remove some of the insert block on the back side like below.. ======== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-27-2008 at 09:16 AM. | |
| Oak Park Mitre Gauge - Need Setup Help.. | Chris H | Jigs and Fixtures | 3 | 07-06-2008 11:39 PM |
| 45 Degree Lock Miter bit | mjeisenbaugh | Router Bits - Types and Usage | 6 | 03-28-2008 08:09 AM |
| Do you use a mitre gauge on a table? | neoshed | Table-mounted Routing | 10 | 11-01-2007 09:32 PM |
| Lock miter bit | Drick | General Routing | 10 | 12-28-2005 10:54 AM |
| Home made mitre fence? | normcatalunya | Jigs and Fixtures | 9 | 11-01-2005 03:51 AM |
