| Router Bits - Types and Usage Discuss help with small bits. in the Routers forums; Good day all. I just got my router today (Mastercraft). It came with a few bits, I was hoping that ... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Registered User New Member |
Good day all. I just got my router today (Mastercraft). It came with a few bits, I was hoping that it would come with a 1 inch straight cut bit. I need to cut box joints that have a 1 inch joints. My question is "Is it possible to build a jig that would allow me to use a 1/2 bit to cut 1 inch joints?" I hope this question makes since. I know it would be easier to buy a 1 inch bit. But it will be a few days before I get back to town. I am brand new to woodworking, with very little knowledge on how to use the woodworking tools to there fullest potential. I hope I posted this in the right place.Last edited by redneck : 04-17-2008 at 11:36 AM. | ||
| | #2 | ||
| Forum Contributer Supreme Forum King |
Hi redneck I think you got it, just make 3 passes to get your 1" wide slot.. ![]() But do take it easy on the Mastercraft ,that's to say only go 1/2 the way in the stock on the 1st. set of passes.. You'er asking the bit/router to do alot of work.. watch the heat on the bit..let it cool down...===========
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html | ||
| | #3 | ||
| Senior Moderator Supreme Forum King |
To expand on what BJ said use this process for the most accurate cuts: Start off by marking the exact location of the cut. Using an edge guide with your router cut in the center of the area to be removed moving your router from left to right with the guide on the top edge of the router. Reposition your edge guide to one side, make your cut, then repeat for the other side. It is best to remove no more than 1/4" in depth per cut, so for a 3/4" deep cut you would make 3 passes of increasing depth before moving the edge guide.
__________________ Mike | ||
| | #4 | ||
Thanks guys for the quick response. After close inspection of the router I will be sending it back. I chucked up a bit and could not get it back out. I had to use pliers. I checked for burs or any other problem that might keep the collet from sliding out, it was under spring pressure. The overall quality of this router is not what I expected. I know you get what you pay for. I don't even think I got that much. I just wanted something to try. So I could see if I would like using a router. I guess I will go ahead and purchase a new one. Any suggestions on a router that would be around $100.00$...Thanks ....Disappointed | ||
| | #5 | |||
Hi redneck For a 100.oo bucks I like the one below,,plus it comes with a quick release on the collet nuts...so you will not need to use a pair of pliers to get the bits out ![]() http://www.sears.com/shc/s/p_10153_...ecemldffidflk.0 Plus if you work it right you can get it on your door step for about 80.oo bucks, buy it on line SUNDAY ( 6:00 PM to 6:00 AM ,see the post for FREE stuff on the forum) and become a member with Sears that will save you about 20.oo to 25.oo bucks... ![]() ======== Quote:
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3 : 04-17-2008 at 02:08 PM. | |||
| | #6 | ||
| Registered User Forum Fanatic |
I can also vouch for this particular router. For a 109.00 bucks I don't think you'll do better. I have one of these for any handheld jobs and I reach for it before I reach for my Hitachi. I thought Mastercraft was only available in Canada?
__________________ Jer Miracle Stick! Made of tough, genuine wood! | ||
| | #7 | ||
Hi Jer MasterCraft You will find them all over eBay and many other spots, they are a low end router.. http://www.shoptoit.ca/shop/product...Id_3297289.html http://cgi.ebay.com/1-4-VARIABLE-SP...Q2em118Q2el1247 Chicago Electric sells one under it's name also.. ===========
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3 : 04-18-2008 at 11:16 PM. | ||
| Magnate Router bits | kp91 | Tool Reviews | 2 | 07-09-2007 03:36 AM |
| Quality bits | RobertJR | General Routing | 5 | 04-19-2006 12:36 AM |
| Need help deciding on bits. | ryan.s | General Routing | 8 | 03-25-2005 09:35 PM |
| router bits from oak park | reds_21 | General Routing | 1 | 02-09-2005 12:59 PM |
| another sorry question about router bits | reds_21 | General Routing | 7 | 12-30-2004 04:31 PM |
All times are GMT -5. The time now is 05:34 PM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
