The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Go Back   Router Forums > Routers > Router Bits - Types and Usage
Reload this Page Best bits for crown molding?
Router Bits - Types and Usage Discuss Best bits for crown molding? in the Routers forums; I would very much like for this thread to continue and develop more discussion of the Freud Wide Crown Molding ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 05-26-2008, 09:41 PM   #31
rstermer
Sr. Member
User Info
Trader Rating: (0)
Gallery: View
Country: USA
rstermer is on a distinguished road
Send Private Message | View Profile
Originally Posted by mftha
I would very much like for this thread to continue and develop more discussion of the Freud Wide Crown Molding bits. The videos and other information says there are 9 possible combinations, but I count 36, but I have no experience with them and am not sure of the aesthetics of the of the unmentioned 27. Does anyone have experience with these bits? I also note that mlcs now has two similar bits.
Mftha-
My research shows there is a huge variation in the price of bits and I wonder whether spending the extra money to buy a first class bit ilike the Freud is justified if one intends to make crown only once. So far I am persuaded by Bobj's opinion expressed above, so am inclined to go with the super carbide bits ($18 each, I'll buy two) unless someone tells me they tried using them on a large run of stock and got an inferior result (since my friend is on a very tight budget, the inexpensive bit, instead of a really nice, and expensive, one like the Freud, Eagle America or MLCS is really a lot more practical, provided it will hold up for the entire run of stock (and that really is THE question.)) I think one of the main conclusions I've reached so far is that I want to use a fixture like the one Bobj designed to support my stock because I think it will ensure uniformity in the cut. I think the fixture design is maybe more important than the brand of bit one uses, but that's just my opinion and I certainly don't claim any great expertise!
Like you, I'd also like to hear from anyone who has used the reversible bits, especially anyone who has used super carbide's version on mdf. I'll ertainly post again when I have something concrete to report.
Thanks for your post,
rstermer
rstermer is offline   Top | Reply with Quote |
Old 05-27-2008, 07:33 AM   #32
Charles M
Forum Fanatic
User Info
Trader Rating: (0)
Gallery: View
Charles M is on a distinguished road
9 possibilities is correct. There are 3 bits that do the top half and 3 for the bottom so you mix and match for 9 profiles. You could conceivably use two tops or two bottoms together but the resulting profile would not be appealing. The issue is the flat portions which are intended to be either in the vertical or horizontal plane when installed at 38°/52°. The MLCS bits you mentioned are for 45° so the look when installed will not be like traditional crown molding.
Charles M
Freud America, Inc.
Charles M is offline   Top | Reply with Quote |
Old 05-27-2008, 09:26 PM   #33
mftha
Sr. Member
User Info
Trader Rating: (0)
Gallery: View
mftha is on a distinguished road
Thanks,
Actually the number I counted should have been 21, the remaining 15 being redundant. But you have answered answered my question about the aesthetics of the uncounted possibilities. Now that you mention it, I also see your point about the MLCS bits.
Tom (NOT Template Tom; I'm nowhere near his league)
One does not know what they are doing until they can make a mistake and correct it.
DO Something, DO ANYTHING to Stop Global Warming
mftha is offline   Top | Reply with Quote |
Old 05-27-2008, 10:00 PM   #34
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/...op_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
bobj3 is online now   Top | Reply with Quote |
Search this Thread:
Advanced Search
molding bit(s) Hamlin Router Bits - Types and Usage 3 01-26-2008 06:39 PM
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 03:36 AM
1/4" shaft bits g-man Starting Off 2 01-03-2006 04:14 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
Router rpm for molding bits Glenmore General Routing 2 09-26-2004 12:10 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
