Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 05-10-2008, 11:53 AM   #21
rstermer
Forum Fanatic
rstermer is on a distinguished road
Originally Posted by bobj3
Hi rstermer
I would suggest MDF if you are goinf to paint it.. MDF comes out clean and takes paint well.
I use a sanding mop when I use MDF it will take the fuzz off quick and give it a nice clean look...
http://www.stockroomsupply.com/The_Sanding_Mop.php
MDF stock is hard on bits, I would suggest you have a extra one on hand just it case.
You can run it by the bit in two passes that will help keep the wear down on the bit plus give you a nice clean looking molding...
The sanding mop is pretty cool. Thanks for the info. Finishing is my least favorite part of woodworking and I'm always looking for easier and quicker ways to get it done.
What grit should be used for mdf?
Too bad the guy who posted on lumberjocks and was making crown on his table saw didn't know about the sanding mop, he could have saved himself a ton of work and a lot of time!
rstermer
rstermer is offline   Top - Reply with Quote
Old 05-10-2008, 12:09 PM   #22
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi rstermer
I use the 180g on the MDF it only take a pass or two to get it smooth and ready for the paint job...
I also have the 220g on a home made shaft,,,for the fine work on hardwood..
here's a snapshot of both of them..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-12-2008, 09:07 AM   #23
gregW
Forum Fanatic
gregW is on a distinguished road
Hi Bob,
Nice job on the molding!
Do you use the sanding mop in a drill press or with a hand drill?
Greg
gregW is offline   Top - Reply with Quote
Old 05-12-2008, 10:55 AM   #24
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Greg
Thanks, "mops" both , they work great once the stock is glued up and in place to get the joints just right...
Originally Posted by gregW
Hi Bob,
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-12-2008, 02:32 PM   #25
gregW
Forum Fanatic
Hi Bob,
Thanks for the tip! I went ahead and ordered two of the 6" mops and one of the mini dremmel ones.
the more I use my router it seems like sanding is the only thing that I spend more time at than cleaning up all the dust and chips..
Greg
Old 05-12-2008, 05:03 PM   #26
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi greg
You'er Welcome ,, I also have the mini dremmel ones they are great for the fine work, I use them alot on the CarveWright stuff..
Hi Bob,
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-13-2008, 12:32 PM   #27
Julie
Forum Geek
Julie's Avatar
Julie is on a distinguished road
Bobj3 said "HI Julie
I would love to see a snapshot of the cove molding you made... "
I just made this, it's pine and has not been touched by sandpaper.
~Julie~
Julie is offline   Top - Reply with Quote
Old 05-13-2008, 02:51 PM   #28
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks for the snapshot Julie
What size of stock did you start with ? and what size is it now...and what size is the cove, is it on the floor or on the counter top ?
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-13-2008, 04:27 PM   #29
Julie
Forum Geek
Julie's Avatar
This is actually a deeper type cove, which I have no idea what size it was to start out, but my guess is it's finished at about 2 1/2" at the widest point. I make my own plans, do my own thing a lot of the time, so I just do the width, depth and whatever that I feel like at the time... quite liberating. In the photo it's sitting on the living room floor, I brought it in from the shop at lunch time, just for you Bob, but it's back out there now.
~Julie~
Old 05-26-2008, 08:48 PM   #30
mftha
Forum Fanatic
mftha's Avatar
mftha is on a distinguished road
I would very much like for this thread to continue and develop more discussion of the Freud Wide Crown Molding bits. The videos and other information says there are 9 possible combinations, but I count 36, but I have no experience with them and am not sure of the aesthetics of the of the unmentioned 27. Does anyone have experience with these bits? I also note that mlcs now has two similar bits.
Tom (NOT Template Tom; I'm nowhere near his league)
One does not know what they are doing until they can make a mistake and correct it.
DO Something, DO ANYTHING to Stop Global Warming
mftha is offline   Top - Reply with Quote
molding bit(s) Hamlin Router Bits - Types and Usage 3 01-26-2008 07:39 PM
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 04:36 AM
1/4" shaft bits g-man Starting Off 2 01-03-2006 05:14 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 10:35 PM
Router rpm for molding bits Glenmore General Routing 2 09-26-2004 01:10 PM
