| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #21 | |
| Registered User Forum Fanatic | Quote:
What grit should be used for mdf? Too bad the guy who posted on lumberjocks and was making crown on his table saw didn't know about the sanding mop, he could have saved himself a ton of work and a lot of time! rstermer | |
| | #22 |
| Forum Contributer Supreme Forum King | Hi rstermer I use the 180g on the MDF it only take a pass or two to get it smooth and ready for the paint job... I also have the 220g on a home made shaft,,,for the fine work on hardwood.. here's a snapshot of both of them.. ==========
| | #23 |
| Registered User Forum Fanatic | Hi Bob, Nice job on the molding! Do you use the sanding mop in a drill press or with a hand drill?
__________________ Greg ------------------------------- |
| | #24 | |
| Forum Contributer Supreme Forum King | HI Greg Thanks, "mops" both , they work great once the stock is glued up and in place to get the joints just right... ![]() ===== Quote:
| | #25 |
| Registered User Forum Fanatic | Hi Bob, Thanks for the tip! I went ahead and ordered two of the 6" mops and one of the mini dremmel ones. the more I use my router it seems like sanding is the only thing that I spend more time at than cleaning up all the dust and chips.. ![]()
| | #26 | |
| Forum Contributer Supreme Forum King | Hi greg You'er Welcome ,, I also have the mini dremmel ones they are great for the fine work, I use them alot on the CarveWright stuff..========== Quote:
| | #27 |
| Registered User Forum Geek | Bobj3 said "HI Julie I would love to see a snapshot of the cove molding you made... " I just made this, it's pine and has not been touched by sandpaper. ~Julie~ Last edited by Julie; 05-13-2008 at 12:51 PM. |
| | #28 |
| Forum Contributer Supreme Forum King | Thanks for the snapshot Julie What size of stock did you start with ? and what size is it now...and what size is the cove, is it on the floor or on the counter top ? ============
| | #29 |
| Registered User Forum Geek | This is actually a deeper type cove, which I have no idea what size it was to start out, but my guess is it's finished at about 2 1/2" at the widest point. I make my own plans, do my own thing a lot of the time, so I just do the width, depth and whatever that I feel like at the time... quite liberating. In the photo it's sitting on the living room floor, I brought it in from the shop at lunch time, just for you Bob, but it's back out there now. ~Julie~ |
| | #30 |
| Registered User Forum Fanatic | I would very much like for this thread to continue and develop more discussion of the Freud Wide Crown Molding bits. The videos and other information says there are 9 possible combinations, but I count 36, but I have no experience with them and am not sure of the aesthetics of the of the unmentioned 27. Does anyone have experience with these bits? I also note that mlcs now has two similar bits.
__________________ Tom (NOT Template Tom; I'm nowhere near his league) One does not know what they are doing until they can make a mistake and correct it. DO Something, DO ANYTHING to Stop Global Warming |
| molding bit(s) | Hamlin | Router Bits - Types and Usage | 3 | 01-26-2008 07:39 PM |
| Magnate Router bits | kp91 | Tool Reviews | 2 | 07-09-2007 04:36 AM |
| 1/4" shaft bits | g-man | Starting Off | 2 | 01-03-2006 05:14 PM |
| Need help deciding on bits. | ryan.s | General Routing | 8 | 03-25-2005 10:35 PM |
| Router rpm for molding bits | Glenmore | General Routing | 2 | 09-26-2004 01:10 PM |
