| Router Bits - Types and Usage Discuss Freud Drawer Lock Bit 99-240 in the Routers forums; I bought the Freud Raised Panel Completer set the other day and for some reason I can not make male &... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Registered User New Member |
I bought the Freud Raised Panel Completer set the other day and for some reason I can not make male & female cuts, that is one cut is face down the other on end straight up they always seem to be male - male or what ever, they do not fit together. I have the Freud DVD on this product and have viewed it countless times and still no fit ,is there a trick to this, or what am I not seeing? Help I am up to my knees in sawdust and running out of wood! RobW | ||
| | #2 | ||
| Registered User Supreme Forum King |
Hi, Be sure that the bit height is 3/8" above the table. Freud site link: http://www.freudtools.com/p-112-drawer-lock-bits.aspx Hope this helps. ![]()
__________________ Ken "Well people, it isn't how good you are, it's how much you can cover that counts". - Bob R. | ||
| | #3 | ||
| Forum Contributer Supreme Forum King |
Hi RobW The key is a push block the norm,, check out the video below it will help you set up the bit and show how to use it with the push block ...that's stuck on to the work stock with double sided carpet tape. http://www.mlcswoodworking.com/shop...ck_video_anchor NOTE*** don't go cheap on the double sided carpet tape use the best with the nylon threads in the tape plus it's super sticky...you don't want the stock to slip when you push it by the bit... ![]() ===========
__________________ Always keep a open mind but not so far as to let yours brains fall out. RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html --------- FREE PLANS from soup to nuts,tons of free plans. www.absolutelyfreeplans.com/ Bj Last edited by bobj3 : 05-09-2008 at 10:52 AM. | ||
| | #4 | ||
SUCCESS is mine thanks to Ken and Bj. I had to build a fence, set the correct hight to 3/8 above table and it was suddenly easy. THANK YOU ONCE AGAIN - RobW | ||
| Drawer lock with Baltic birch | woodcarver | Table-mounted Routing | 3 | 01-13-2008 11:50 PM |
| EZ Link | BlueGoose | Introductions | 2 | 03-09-2006 12:52 PM |
| Drawer joints - Box vs. Dovetail vs. ??? | ChevyNomad | General Routing | 2 | 01-14-2005 10:20 AM |
| Making a Zero Clearance Fence for Drawer Lock Bit | gerrym526 | Table-mounted Routing | 3 | 12-16-2004 12:43 PM |
All times are GMT -5. The time now is 11:19 AM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
