The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Go Back   Router Forums > Routers > Router Bits - Types and Usage
Reload this Page Freud Drawer Lock Bit 99-240
Router Bits - Types and Usage Discuss Freud Drawer Lock Bit 99-240 in the Routers forums; I bought the Freud Raised Panel Completer set the other day and for some reason I can not make male &...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 05-07-2008, 06:34 PM   #1
RobW
New Member
User Info
Trader Rating: (0)
Gallery: View
RobW is on a distinguished road
Default Freud Drawer Lock Bit 99-240
Send Private Message | View Profile
I bought the Freud Raised Panel Completer set the other day and for some reason I can not make male & female cuts, that is one cut is face down the other on end straight up they always seem to be male - male or what ever, they do not fit together. I have the Freud DVD on this product and have viewed it countless times and still no fit ,is there a trick to this, or what am I not seeing? Help I am up to my knees in sawdust and running out of wood!
RobW
RobW is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 05-07-2008, 06:57 PM   #2
Hamlin
Supreme Forum King
User Info
Trader Rating: (0)
Gallery: View
Country: Kansas - USA
Hi,
Be sure that the bit height is 3/8" above the table.
Freud site link: http://www.freudtools.com/p-112-drawer-lock-bits.aspx
Hope this helps.
Ken
"Well people, it isn't how good you are, it's how much you can cover that counts". - Bob R.
Hamlin is offline   Top | Reply with Quote |
Old 05-07-2008, 07:02 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Hi RobW
The key is a push block the norm,, check out the video below it will help you set up the bit and show how to use it with the push block ...that's stuck on to the work stock with double sided carpet tape.
http://www.mlcswoodworking.com/shop...ck_video_anchor
NOTE*** don't go cheap on the double sided carpet tape use the best with the nylon threads in the tape plus it's super sticky...you don't want the stock to slip when you push it by the bit...
Always keep a open mind but not so
far as to let yours brains fall out.
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
FREE PLANS
from soup to nuts,tons of free plans.
www.absolutelyfreeplans.com/
Bj
bobj3 is offline   Top | Reply with Quote |
Old 05-08-2008, 01:01 PM   #4
RobW
New Member
User Info
Trader Rating: (0)
Gallery: View
SUCCESS is mine thanks to Ken and Bj.
I had to build a fence, set the correct hight to 3/8 above table and it was suddenly easy.
THANK YOU ONCE AGAIN - RobW
Search this Thread:
Advanced Search
Drawer lock with Baltic birch woodcarver Table-mounted Routing 3 01-13-2008 11:50 PM
EZ Link BlueGoose Introductions 2 03-09-2006 12:52 PM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 10:20 AM
Making a Zero Clearance Fence for Drawer Lock Bit gerrym526 Table-mounted Routing 3 12-16-2004 12:43 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
