Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 06-02-2008, 03:46 PM   #1
nicksorenson
Jr. Member
nicksorenson is on a distinguished road
Default New Guy with Bearing Bit question FREUD
Hi everyone,
I've got a few questions about bearing bits/
1. I use mostly Straight Pattern (bearing between cutter and shank) bits 1/2" diameter 1" cut depth. What is the best bit I can buy? I'm using Freud right now and it seems to work pretty well.
2. Where is the best/cheapest place to buy these 1" length straight pattern bits?
3. How do I keep these sharp?
4. Are Price-cutter's bits any good?
Lastly, I'm using this to cut 1/2" ply following a template. It is zipping right through the plywood right now. But I want to have bits that I can use for several of these without replacing. Do I need to jigsaw cut close to the template before cutting flush trim with the router? I've found it faster to skip the jigsawing and just use the router.
thanks!!
Nick
nicksorenson is offline   Top - Reply with Quote
Old 06-02-2008, 05:42 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Nick, as I answered in your other thread, cut first with a saw for speed and to save wear on your bits. Freud makes quality bits, and they are ranked with Amana and CMT at the top of the list. Whiteside is #1 in all testing to date, by every source. Finding the best price is up to you. Professional sharpening of quality bits is the way to go. Many companies offer this service.
Old 06-02-2008, 06:08 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Nick
" Where is the best/cheapest place to buy these"
What are you paying now ?, it's hard to find the best price without knowing what to beat.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-02-2008, 06:21 PM   #4
nicksorenson
Jr. Member
Thanks Mike,
How do CNC Machines cut through solid wood all day long? Where can I get a bit that'll put up with that kind of abuse!
Not that I'm lazy and want to avoid the extra step of a jigsaw (I'm cutting a circle out for a speaker). But I'm repeatedly making these speaker faces and want to get a bunch done in a hurry by just following the template if it's possible?
Curious if there's a router bit safe way to do it without bandsawing/jigsawing?
Old 06-02-2008, 06:27 PM   #5
nicksorenson
Jr. Member
Originally Posted by bobj3
HI Nick
What about this for Freud?
Bellew Saw and tool $24
and this for Price Cutter?
There are some for $8 at PriceCutter that will work. Of course the bearings on the wrong side but I'll adjust by switching the template and workpiece and using the table.
edit: Sorry I had links but I couldn't get them to work here. Not sure why.
Old 06-02-2008, 06:54 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Nick
"Freud 1/2" pattern bit"
CMT for 21.oo
http://www.amazon.com/CMT-811-127-11...2446116&sr=1-1
CMT for 19.oo
http://www.sommerfeldtools.com/prodi...number=151271B
Both CMT bits with free shiping
Freud for 20.oo
http://freud-tools.com/freudtopbear.html
WhiteSide 20.oo
http://woodworkersworld.net/template_bits.shtml
Eagle America Router Bits at Pricecutter
18.OO
http://pricecutter.com/pattern-cutter/p/P11-1237B/
Ebay 18.oo
http://cgi.ebay.com/1-pc-1-2-SH-2-Bl...742.m153.l1262
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-03-2008, 08:01 AM   #7
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
Originally Posted by nicksorenson
Thanks Mike,
CNC machines have carefully controlled feed and rotational speeds which ensure that the bit stays as cools as possible for longest life. The key to long life is keeping the carbide cool and the chip size produced when cutting is the greatest factor. A properly sized chip will dissipate heat most efficiently. For hand fed operations you should adjust the router speed so that a safe and comfortable feed rate gives you the cut quality you want without burning. Also, in plywood the glue lines will dull the bit more quickly so you should be able to extend the life of the bits considerably by changing the height a few times throughout its life.
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 06-03-2008, 12:25 PM   #8
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Hi,
Bits from Pricecutter are good quality bits. The few I have from them, I haven't had any problems with. I prefer using Freud, CMT, Whiteside, OP bits over others but, all comes down to what I intend on using it for and how much I want to spend at the time.
For your link posting problem, you need atleast 10 posts before you can post links.
Ken
"A VETERAN"
Old 06-03-2008, 11:18 PM   #9
nicksorenson
Jr. Member
Thanks Fellas,
I bought a pile of bits on sale at price cutter (porter cable, pricecutter house brand, and some other off brand. I've got a few of there bits from a while ago and they seem just fine. I like them.
Good to hear from some folks who have more experience than myself.
Nick
Old 06-04-2008, 06:09 AM   #10
caliban
New Member
caliban is on a distinguished road
That extra step of cutting with a jigsaw before routing reduces my MDF dust by 80 % or so, and using a circle jig on the jigsaw takes only a minute or two.
I have a dust collector system, but MDF dust still gets everywhere.
caliban is offline   Top - Reply with Quote
Top bearing sliding up shaft MisterHeavy Router Bits - Types and Usage 3 04-28-2008 03:02 AM
DC Question angus Lobby 3 03-31-2008 08:29 PM
Removing bearing? Drugstore Cowboy Router Bits - Types and Usage 3 06-23-2007 04:05 PM
Freud router question mpphoto General Routing 12 05-07-2007 09:22 AM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 2 10-22-2005 07:41 AM
