| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User Jr. Member | I've heard spiral bits are good for fast plywood cutting. What is the fastest bit to quickly cut through 1/2 ply following a pattern? |
| | #2 |
| Senior Moderator Supreme Forum King | Nick, you should rough cut your wood with a jig or band saw leaving perhaps a 1/4" to trim with your router. Saw blades are always cheaper than router bits and are designed for fast cutting. Bits to use on plywood depends on the type of cut: a through cut can be done with either a straight or spiral cutter or a compression cutter.
| | #3 |
| Forum Contributer Supreme Forum King | Hi Nick It sounds like you should stick with the bit you are now using, unless you want to make new patterns and use the brass guides.. ======
| Bit for corner of plywood | rharveyva | Router Bits - Types and Usage | 5 | 03-24-2008 02:01 PM |
| Problem Rabbeting Plywood | JDługosz | Portable Routing | 25 | 01-14-2008 01:56 PM |
| Squaring plywood panels | ShaneB | Table-mounted Routing | 37 | 12-22-2006 07:40 AM |
| Dovetails In Plywood | rmaxa | Router Bits - Types and Usage | 6 | 12-19-2006 11:00 PM |
