| | #1 |
| Registered User New Member | hi all, I'm wondering if a horizontal raised panel bit with a back cutter can be used if you remove the back cutter. I can't find any information from the manufacturer (Freud). I purchased a 3 pc. set that included a vertical ogee bit and realized I should have purchased the set with the horizontal raised panel bit. I went out and bought a bit with back cutter from Samona and found that it did not match the Freud rail & stile pattern especially the tongue thickness. It was less than 1/3d the cost of the freud bit and makes a horrible cut. Freud's quadra cut bits seem the way to go. Thanks, Brian |
| | #2 |
| Senior Moderator Supreme Forum King | This post fell through the cracks. Send a PM to member CharlesM, he works for Freud and will give you the best answer.
__________________ Mike |
| Already Problems | neuschu | Introductions | 7 | 01-22-2008 10:32 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 02:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
| Question about raised panel router bits | LBrandt | Table-mounted Routing | 2 | 07-08-2006 09:47 AM |
