Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 06-23-2008, 11:20 AM   #1
henseman
New Member
henseman is on a distinguished road
Question horizontal router bits with backcutters
hi all,
I'm wondering if a horizontal raised panel bit with a back cutter can be used if you remove the back cutter.
I can't find any information from the manufacturer (Freud). I purchased a 3 pc. set that included a vertical ogee bit and realized I should have purchased the set with the horizontal raised panel bit. I went out and bought a bit with back cutter from Samona and found that it did not match the Freud rail & stile pattern especially the tongue thickness. It was less than 1/3d the cost of the freud bit and makes a horrible cut. Freud's quadra cut bits seem the way to go.
Thanks,
Brian
henseman is offline   Top - Reply with Quote
Old 07-20-2008, 12:50 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
This post fell through the cracks. Send a PM to member CharlesM, he works for Freud and will give you the best answer.
Already Problems neuschu Introductions 7 01-22-2008 11:32 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 10:47 AM
