| This is a discussion on Dewalt 625 - Large Raised Panel Bit within the Router Bits - Types and Usage forums, part of the Routers category; Has anyone tried to use a large raised panel bit with the DW625? In particular, ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Has anyone tried to use a large raised panel bit with the DW625? In particular, will it allow the use of 3 3/8" Whiteside Panel bit, 6000s series? I could not find anything in the manual or info on this site. Thanks - Rick | ||
| | #2 (permalink) | ||
| Forum Contributor ![]() |
HI open_market Your DeWalt 3HP router should take on the 3 3/8" panel bit easy ![]() Just turn the speed all the way down and make 2 or 3 cuts on the panel. 1st. cut 1/2 the way ,2nd. cut 90% of the cut ,3rd. pass is the clean up pass. Don't move the bit up or down ,just the fence...in or out to get the job done. Use a stop block on the back side of the fence if you are making more than one panel...just a quick and a fast way to get it setup for all the panels. clamp the stop block to the table top, Stop block for the last pass, spacer block for the 1st. and 2nd pass... ===
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 10-03-2008 at 05:36 PM. | ||
| | #3 (permalink) | |||
| | #4 (permalink) | ||
| Registered User ![]() Join Date: Jun 2009 Location: Exmoor, West Somerset, England First Name: Steve Posts: 11 ![]() |
I WOULD HAVE THOUGHT THAT THE 625 WITH A FIXED SPEED OF 20000 RPM IS A BIT QUICK FOR THIS BIT. Steve | ||
| | #5 (permalink) | ||
Hi Steve It is,,,but most in the states can get a router speed control device(for 20.oo dollars) that holds the speed down to 8,000 rpms..I know you have the 220 system in the UK and I don't think they make one that will work in the UK.. ![]() ======
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #6 (permalink) | ||
Hmmm, are there different models of the 625? Mine is variable speed and I run it on lowest setting for large bits like this...around 8000 rpm IIRC.
__________________ - Frank Woodworking is more than a hobby. It is a journey of discovery, An application of innovation and creativity, And an opportunity at self improvement. | ||
| | #7 (permalink) | ||
| Retired Moderator ![]() |
When jumping world wide we find that not all routers are created equal. Not sure of this situation.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #8 (permalink) | ||
| Raised Panel Vertical or Horizontal Sets? | WoodyRon | Router Bits - Types and Usage | 8 | 11-24-2007 02:54 PM |
| Raised Panel Bit | rmaxa | Router Bits - Types and Usage | 3 | 09-13-2006 09:56 AM |
| What size of Raised Panel Bit? | SandyT | Table-mounted Routing | 29 | 07-17-2006 10:34 PM |
| Question about raised panel router bits | LBrandt | Table-mounted Routing | 2 | 07-08-2006 09:47 AM |
| research for raised panel doors | presumed_druid | Table-mounted Routing | 4 | 01-13-2006 10:47 PM |
