| This is a discussion on safety / use of extension ....... within the Shop Safety forums, part of the General Woodworking category; I have an older 2 older craftsman router tables that required the router to be ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I have an older 2 older craftsman router tables that required the router to be mounted to the table top. Changing bits is hard to do from below the table despite removing the plastic shields etc. Until I get around to making another table or getting enough money to buy one I was wondering about the use of an exterder shaft. Several companies make them and they all claim they are balanced etc. But I worry about how safe they really are. In case I'm not explaning myself well.... What I'm talking about is a part that slips in the router like a bit does then extends the location where the bit mounts about 1 1/4" allowing the bit changing to be done above the table. Comments anyone? Ed | ||
| | #2 (permalink) | |||
Ed | |||
| | #3 (permalink) | ||
| Retired Moderator ![]() Join Date: Sep 2004 Location: Mountain Top Pennsylvania First Name: Glenmore Posts: 2,059 ![]() |
I have an extension for my router table wasn't quite the same type you have I have one with the regulor one with a 1/2" collet and was warned about using the bigger molding bits they basicly told me to keep it for the smaller things such round over bits and hope for the best. They told me about vibration and the flex of the extension and the worry of it loosing while it is runnning. | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #4 (permalink) | ||
| The Router Guys ![]() |
Only thing I see is the add on collet will reduce the depth of cut on your plunge router. And a dumb question: "the add on collet is balanced, right?"
__________________ Rick and Bob The Router Guys Well I have just completed my first PDF E-Course, which is 10 embedded lessons from the Router Workshop Video Series. This is a must have PDF that you can get some very good pointers on how to use the router. Get your FREE copy here! Looking for personal woodworking blogs that have been blogging for more than 6 months. If you know of any blogs that have good woodworking information, please let them know about my Blog Carnival. Click here to submit your blog to my Carnival. | ||
| | #5 (permalink) | |||
One example is at: http://www.pricecutter.com/html/cata....asp?id=334576 Ed | |||
| | #6 (permalink) | |||
| Registered User |
i am using the "EXTREME EXTENSION" router extension in a DEWALT 625 router- works great!!Quote:
| | #7 (permalink) | ||
| Router King ![]() |
You are using older router to extend the shafts lenght. Any runout will be greater at the end of the extension. Bearing wear vibration may also be increased.
__________________ ![]() | ||
| | #8 (permalink) | ||
I ordered an xtreme xtension and have it sitting next to me as I type this. I was happy until I read down to the Maintenance part of the insturctions. Now I will quote what is written there. "Under extreme load the locking wedge is designed to automatically tighten onto the bit's shaft. If this occurs a slight burr will be left on the bit's shaft. Use a metal file to gently remove only the burrs raised edge. Under normal use the locking wedge can leave a slight impression in the shank of some router bits. This will not affect the accuracy or performance ot the extension or bit" Just wanted you to know in case you decide to order one....... Ed | ||
| | #9 (permalink) | ||
| Registered User |
I have a Ryobi plunge router with a 1/4" collet. I made a router table this past weekend, but as you all know, now I need a collet extension. Does anyone make an extension for a 1/4" collet? | ||
| | #10 (permalink) | |||
Ed, try this web site. http://www.mlcswoodworking.com/ g-man | |||
| What price do you put on safety? | kp91 | General Routing | 21 | 07-23-2010 02:10 AM |
| Jet Tablesaw extension with Jessem RouterLift System | A-Pat-Co | Table-mounted Routing | 12 | 04-17-2010 12:46 AM |
| Already Problems | neuschu | Introductions | 11 | 12-15-2009 07:01 AM |
| Is workshop safety needed? | Check twice! | Shop Safety | 18 | 07-12-2008 10:27 PM |
| Safety Pin Schmafety Pin | RustyW | Jigs and Fixtures | 6 | 08-25-2007 11:24 AM |
