| | #1 |
| Registered User New Member | I purchased a set of 1/4" rail and stile bits a couple of years ago. After hearing Bob comment about bit safety when using larger bits, I put them in a cupboard and never tried using them. I now have a 1/2" router, is it safe to use them using a 1/4" to 1/2" collet? Thanks |
| | #2 |
| Registered User New Member | It's the same situation - You still have a 1/4" stem on a large diameter cutter(s) You can more safely use the step-down collet for smaller bits..........Bob |
| | #3 |
| Registered User Dedicated Member | Probably warning you of the larger ones rising up. When you tighten a collet always push it in all the way and then pull out about 1/4 inch before tighting. If not it won't tighten right and can pull out.
__________________ God created man, then woman and man said, Give me my wood shop! |
| | #4 | |
| Registered User New Member | Quote:
You can use the collet to adapt your new router to small diameter 'cutters' on 1/4" bits, which is what it's for. Bob Dennison | |
| | #5 |
| The Router Guys Forum King | The problem is we have a 1/4" shank on a router bit that has over a 1" diameter cutting edge leaving limited suport at the base of the bit. With the 1/2" collet on the router and the 1/4" sleeve we still have not supported the bit properly. I would say no to using the 1/4" shank rail and stile bit. Porter Cable have produced a new router bit called Posi-stop that shows how to support the 1/4" shank bits with large diameters. Hope this was helpful,
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #6 |
| Registered User Sr. Member | Bob.........do you recommend buying only 1/2" bits? The reason I ask is that I bought a set last week and they all are 1/4". They have the same assortment in 1/2" at the same price. I have very little exp. with a router other than cutting dadoes and rabbets. Thanks. |
| | #7 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #8 |
| Registered User Sr. Member | Thanks for the info and thanks for setting up this web site. I live in West Texas and I've watched your show only twice.....because I can't find a schedule. Do you publish times and dates for your show.........sure would be helpful, |
| | #9 |
| The Router Guys Forum King | I would but there are 300 plus stations that have access but not all run it at the same time or place. I have a link to PBS stations from routerworkshop.com that might help on the times, check it out
| Is workshop safety needed? | Check twice! | Shop Safety | 18 | 07-12-2008 10:27 PM |
| Safety Pin Schmafety Pin | RustyW | Jigs and Fixtures | 6 | 08-25-2007 11:24 AM |
| question safety pin | warped | Table-mounted Routing | 2 | 02-22-2006 06:33 AM |
| What price do you put on safety? | kp91 | General Routing | 13 | 01-08-2006 08:15 PM |
