Paddle switch - Page 2 - Router Forums
post #11 of 16 (permalink) Old 11-26-2012, 03:51 PM Thread Starter
IC31's Avatar
First Name: Dave W
Originally Posted by jschaben View Post
Hi Dave - That's a good switch, I put one on my Ridgid table saw. You didn't say which saw you have but neutral (or both legs of the 220) must run through that switch for it to work correctly. It is what is called a "magnetic" switch. That simply means there is a latching relay internally which keeps the saw powered on. The biggest advantage is that if power is lost while running, it won't automatically start running when power is restored.
You can preview the installation instructions by clicking the "Manual - PDF" button on the Grizzly website.
John - I've already pulled the instruction sheet - and have to say that I'm not really impressed with their translated from Chinese wiring diagram, but have seen worse. I am currently running my saw wired for 110VAC as I only have one 220 source and my JET 650 dust control system is on that - but might just have to sneak in another outlet.
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is offline
post #12 of 16 (permalink) Old 11-26-2012, 04:05 PM
First Name: Duane
John, are you sure? It is not advertised as magnetic. Grizzly does carry magnetic switches, but I am pretty sure that one is not.
Dmeadows is offline
post #13 of 16 (permalink) Old 11-26-2012, 04:07 PM
First Name: ray
Grizzly maks two versions of this switch I used the heaver duity one on my 3 HP band saw it works great.
Ray
rayschimpf is offline
post #14 of 16 (permalink) Old 11-26-2012, 07:46 PM Thread Starter
IC31's Avatar
First Name: Dave W
This is the actual manufacturer's data sheet for a Kedu HY56;
http://www.kedu.cn/PDF/2/p59-60%28hy56%29.pdf
and their home page;
Untitled Document (yep, it really is a link)
From the descriptive lit on that home page, it sounds like it's a magnetic switch tho Grizzly doesn't advertise it as such. We'll see what it really is in a couple of days when it arrives from Grizzly/Missouri
Dave W
IC31 is offline
post #15 of 16 (permalink) Old 11-30-2012, 02:18 PM
I just went and checked, I have the 8241 which is the 120V version, not rated for 220 so I can't really be sure.
John Schaben
jschaben is offline
post #16 of 16 (permalink) Old 12-06-2012, 07:58 AM Thread Starter
IC31's Avatar
First Name: Dave W
The switch arrived - not a bad looking product, but ------ it is NOT a magnetic switch. I actually had to take the mounting bracket off to fit it into the existing JET table saw box ---- then came the fun of finding a couple of springs that did their escape 'action'. It works nicely with the temporary Leeson 1Hp motor that is replacing the JET motor while I try to find a replacement cooling fan.
A note about that Leeson motor - it came off a recently deceased 35-40 year old Craftsman air compressor. It starts much harder then the JET and while less advertised Hp seems to be stronger.
Dave W
IC31 is offline
Human Verification
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Grizzly paddle on/off switch guitardemon Table-mounted Routing 9 03-18-2012 06:49 AM
Paddle kill switch and Woodpecker's radius jig. Timmberman Table-mounted Routing 5 07-15-2011 07:03 PM
paddle switch Ells Table-mounted Routing 5 05-01-2011 03:33 AM
wiring a safety paddle switch new fresh start Introductions 5 08-10-2010 12:03 AM
