Go Back   Router Forums > General Woodworking > Shop Safety
Shop Safety Various bits of information, tips, questions and comments on general work shop safety. If you have any questions or a comments regarding a safe way to do a specific procedure in the shop, share it here.
Thread Tools Display Modes
Old 07-02-2007, 09:50 PM   #1
kp91
Forum King
kp91's Avatar
First Name: Doug
Default Safety tip- which cord is which?
I can't remember if I shared this tip here or not, but I picked up this idea from a common shipyard practice. When the shipyard works on our ships, they have racks of welders, cutting torches, and air manifolds stationed all over the ship. From here, gear is run to job sites. To keep track of what goes where, they tag the ends of the hoses at the manifolds so the right one can be shut off without having to trace the hose.
When I'm working, I usually have 2 router motors that I'm working with, because I hate to change bits. To make sure I plug in or unplug the right tool when I have more than one on my bench or table, I use colored tywraps. One on the cord by the motor, one by the plug. It makes identifying each one a quick and easy process.
It really comes in handy at my cordless tool charging station, where 3 chargers share 2 outlets. The blue one is the makita, the green one the hitachi.... Okay, so I am a little bit obsessive sometimes.
1 John 1:9
Old 07-02-2007, 10:02 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Great idea Doug, thanks for sharing... and I hear yah on the cordless charger stations!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 07-02-2007, 10:07 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Doug, color coding does make things easy. Air nailers are another good example. Use green for your brads and brad nailer, blue for your finish hails, red for pins. It helps make sure you grab the right fasteners for the tool you are using.
Old 07-02-2007, 10:40 PM   #4
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Very good, Doug!
Sure beats the food twistems my wife gets at the market!
... or a label wrapped around the wire & back on itself!
Now, I guess you can get those colored cable ties on ebay, etc.?
Edit:
Good for computer network cables too... yes?
Joe Lyddon is offline   Top - Reply with Quote
Old 07-02-2007, 10:57 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi kp91
That's a good tip,,, I used about the same on my air lines,, I have the compressor in the corner of the shop and have 1/2" copper tubing running all over the shop but I use flex lines that plug into the air manifold at the compressor and I use yellow,red,blue,green,white on the hose ends so I know which one I need to plug in for the shop, I unplug the lines every nght ,I do this just in case the lines blows and so it will not burn up the motor on the compressor at night time or if I'm not home or in the shop I have cooked one 5hp. motor in the pass and it was a expensive lesson to learn....
I need to find a device that will power down the motor if it runs longer than 15mins. at one time...but will reset with a button or with a switch once it's fliped back on.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-02-2007, 11:40 PM   #6
kp91
Forum King
kp91's Avatar
First Name: Doug
Joe,
Home depot, Wal-mart, harbor freight and big lots is where I've seen the neon and colored cable ties.
Bob,
You could use a water heater timer ($20), or some other heavy duty timer, so that your compressor won't start up at night. I can't think of a 'cheap' way of putting a 15 minute run time on your compressor, a good 20 amp TDOE relay can be $60 plus.
The switch I listed below has a bunch of trips, you could set it so it could only run every other 15 minutes during the normal day.......
(I just kill the 2 20 amp breakers in my shop when I leave)
http://surpluscenter.com/item.asp?UI...8-250&catname=
1 John 1:9
Old 07-03-2007, 12:17 AM   #7
Senior Moderator
Supreme Forum King
You will also find colored velcro straps at your dollar store for identifying tools or wire bundles.
Old 07-03-2007, 12:30 AM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Doug
I have a timer like the one in link that I use on the pump for the pond pump that works great for that type of job.
I have been playing with a device for a long time, (for the comp.) the one I have come with will pull a 50amp. beaker in a box that the power cord plugs iinto for the comp.,it runs off a clock IC with a 12volt DC relay that runs a auto. door lock/trunk device that will pull or push the breaker off and on but it's so dam big, but it needs to be because of the 50amp. pull of the comp. I just need to find a electrical engineer to get all the parts into a standard outlet box for a 50amp.service... 12 volt 15amp. power supply,breaker,outlet,12 volt relay,IC clock,etc. lot's of luck
Joe,
Bob,
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-03-2007, 07:48 AM   #9
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Bj, I know that I'm going to regret asking, but why not do as Doug suggests and as I do?
"(I just kill the 2 20 amp breakers in my shop when I leave)"
Years ago I had a garden reticulation system where water from the bore was insufficient so I used to pump it into a 1000gal. tank and reticulate from there with a separate pump. The point of this story is that one night the tank sprung a leak and the pump kept going all night because I had fitted an air pressure level switch to the tank. I therefore fitted a solar time switch to make sure it didn't happen again.
Harry
harrysin is online now   Top - Reply with Quote
Old 07-03-2007, 09:19 AM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
Well to start with breakers in the load center are not made to used as a switch that's to say they are not made to be turn off and on to many times unlike a light switch on the wall,,, just not made the same way inside the breaker.
The light switch is a $1.25 item and my 50 amp.breaker runs about $28.oo dollars...
And then again my breaker cabinet/load center is in the corner of the shop and it would take a bit of work to get to it plus that's why I have a comp.that will keep the air up at 175lbs.when I need it but I don't want it to run at night time or when I'm not home and a device would take care of that error real quick...15mins.run time max thing....at one startup..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Is workshop safety needed? Check twice! Shop Safety 18 07-12-2008 11:27 PM
Safety Pin Schmafety Pin RustyW Jigs and Fixtures 6 08-25-2007 12:24 PM
power supply/extension cord questions rprice54 Tools and Woodworking 10 06-28-2006 05:31 PM
What price do you put on safety? kp91 General Routing 13 01-08-2006 09:15 PM
