Help
Go Back   Router Forums > Other > Show N' Tell
For Birch M&T jig
This is a discussion on For Birch M&T jig within the Show N' Tell forums, part of the Other category; Originally Posted by bobj3 For Brich Just added some more snapshots for Birch The stock ...
LinkBack (1) Thread Tools Display Modes
Old 11-22-2008, 11:04 PM   #11 (permalink)
First Name: Luke
weerts is on a distinguished road
Report Post Report This Post!
For Brich
The stock in the jig is 3/4" wide MDF ..
Manual. I got a copy on the way Brich from a nice guy on Ebay
"It turns out I have to open the box to add another
Item. If you want a copy of the manual I will copy
it and mail it off to you for $5. to cover postage,copy and envelop cost.
Let me know today or it will be gone. My e mail is "
- woodworkerplus
The only thing bad about this jig is/was the clamping system,,but I took care of that error,, I drilled holes in the clamp bolt threaded rods and put in some cotter pins so the clamp would not fall off and made a new push block out some MDF stock, now when I back off the clamp it comes back and the push block now puts presser on the stock in the right place.. without caming out one way or the other ..
By the way the brass guide I asked about didn't need because I had a 1 1/2" O.D. brass guide that worked out just right for this jig..
The one that comes with the jig is a funky steel one with two holes in it to hold it in place , so it worked for the best in the long run.
Hi all,
Last Thursday, I was also given one of these Craftsman M & T jigs. The price is right -- free. It is missing the guide however.
Bob, you mentioned using a 1 1/2" O.D. brass guide. I have some brass guides for my Porter Cable router, but not that large. It seems like the brass guide you show in one of the pictures is smaller than 1 1/2" so I thought I'd double check. Can something other than 1 1/2" be used?
Luke
weerts is offline
Old 11-23-2008, 12:22 AM   #12 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi weerts
Yep, you can use a smaller guide(s) but the 1 1/2" is just the right size..
to put in the slots,, but when you want to make tetons you will want to use a smaller OD guide,,,the jig calles for you to use a 1/4" router bit but you can use 3/8" or 1/2" bits as well..
You will see in the snapshot below with a plastic ring you can make easy to get the 1 1/2" OD that works the best..
Just a note *** the 3/4" brass guide and a 3/8" router bit is just right,when using 3/4" wide stock when you want to put on some tetons on the ends of the stock..
To make the plastic adapter = put some 1/4" thick or 1/2" plastic on the drill press on top of some scrap stock, clamp the plastic and the scrap sock down to the drill press top, then chuck up a 1" bit ,drill the 1" hole out then chuck up a 1 1/2" ID hole saw, then cut out the ring,,the 1 1/2" hole saw should be just a little bit bigger than 1 1/2",,, once you have the ring, sand down the outside of the ring so it's dead on 1 1/2", then use some super glue and glue it to the 1" brass guide,,( if you don't want to use the one in the set you can buy a spare at Rockler) once you have that done you now have a adapter the will just fit just right in the Craftsman M & T jig..
Plus make a setup block, that's 1 1/2 x 3/4" " x 3/4" put a line on it all the way around the block,this will setup the slide part of the jig on dead center of the stock..then when you want to put in the slots, just mark the stock in the center, move the metal slide bars until it's on the center line on the stock, from this point on you don't want to move the metal side bars,,then when you want to put on the tetons chuck up a 3/8" router bit and the 3/4" OD brass guide and go all the around the inside of the metal side bars, it should be dead on...
This jig will also put in dowel pin holes/bead lock holes, very easy and quick and dead on
http://www.routerforums.com/86539-post8.html
hope this little tip helps
It's a great little jig , you will see almost the same thing at Rockler that sells for about 300.oo bucks...
Originally Posted by weerts View Post
Hi all,
Luke
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 11-24-2008, 08:05 AM   #13 (permalink)
First Name: Luke
Hi Bob,
Thank you so much for all the useful information on the jig. I've ordered a 1 1/2" guide from Lee Valley and soon I'll be all set up.
Thanks again,
Luke
weerts is offline
Old 11-24-2008, 08:39 AM   #14 (permalink)
bobj3's Avatar
HI Luke
You're Welcome
If you are going to Lee Valley you may also want to pickup a clear base plate,it will make it just a bit essayer to mount the 1 1/2" guide..
or you can get it from ptreeusa also or from other woodworkers supply outlets like MLCS that has free shipping..
Router Base With Centering Pin
item #1051
Pre-drilled for most any router, this plate also includes
a smartly designed centering pin that centers the guide to the router collet.
Install a Porter-Cable style guide bushing
(not included), use the centering pin to line-up the base plate to the collet, install your bit for perfect alignment.
Plate has a 1-3/16" dia. center hole that will accept our inlay or template guide kit.
http://www.ptreeusa.com/routerAcc.htm#20262
Type " A " or " C "
http://www.mlcswoodworking.com/order.../routacc2.html
Hi Bob,
Thanks again,
Luke
Part Finder
Bob J.
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/show-n-tell/10133-birch-m-t-jig.html
Posted By For Type Date
» 46 Router Jig Plans: Router Dado Jigs, Mortise Jigs, Circle Cutting Jigs and MORE - ToolCrib.com Blog This thread Refback 10-25-2009 08:28 PM
