Floating Shelves - Page 2 - Router Forums
 61Likes
post #11 of 43 (permalink) Old 01-07-2017, 11:24 AM
TenGees's Avatar
First Name: Paul
Those turned out nice and the mounting is much sturdier looking than some plans I've seen.
MT Stringer likes this.
TenGees is offline
post #12 of 43 (permalink) Old 01-07-2017, 11:36 AM
RainMan 2.0's Avatar
Same here Paul . I'm wondering what the height limit would be ? Meaning I wonder how thin the shelf can be made and still have enough strength .
The height of those do look good though .
Mike ,did you cut the inside frame 3" tall , as it doesn't look like a full 2/4 standing on end ?
Life is hard . Harder if your stupid
RainMan 2.0 is offline
post #13 of 43 (permalink) Old 01-07-2017, 11:46 AM
Everend's Avatar
First Name: Everend
"[pocket holes]... is the strongest form of joinery that you can use with two pieces of wood..." Really?
It depends on what you want to put on the shelf. My brother made these back in October.
My hidden bracket system worked out very well. I used a half inch by half-inch rabbit bit on the router along each edge and in the center of the back of the shelf. Then I cut out half inch by half inch oak strips and I pre-drilled and mounted into the wall and slid the shelf right over them. The oak is strong, just one screw down from the top to set it. They were pretty snug on the ledgers.
Everend is offline
post #14 of 43 (permalink) Old 01-07-2017, 12:08 PM
Your brother did a good job . I have to say floating shelves are the coolest
Gaffboat likes this.
post #15 of 43 (permalink) Old 01-07-2017, 12:20 PM
Everend's Avatar
First Name: Everend
I texted him the link to this thread so he called me. He pointed out that his shelves are supported on three sides. If you wanted to do floating shelf using one of these brackets, You would need to cut the drywall back so the bracket can be lag screwed directly to the stud. Too much weight on one of these brackets would crush the drywall.
Everend is offline
post #16 of 43 (permalink) Old 01-07-2017, 12:26 PM
Everand thanks for the heads up . I think I'm going to make some deeper simular to Mikes .
Here's where they would work great , on the left above the toilet . I built the wall out on the right in order to counter sink a medicine cabinet in , but I used a round edge for the corner where you mud .
So I'm thinking, keep the shelves narrower than the whole width of that space , or they may look odd .
Sorry for sidetracking your thread Mike
post #17 of 43 (permalink) Old 01-07-2017, 12:33 PM
Everend's Avatar
First Name: Everend
Looking good Rick, I agree they would look better floating free rather than going from edge to short rounded edge there. Is that where you used a router to make room for the pocket hole 2x4?
RainMan 2.0 likes this.
Everend is offline
post #18 of 43 (permalink) Old 01-07-2017, 12:38 PM
Yes it worked out very well . Hopefully I never damaged the router with that foam dust .
Gotta love pocket holes !
post #19 of 43 (permalink) Old 01-07-2017, 01:30 PM
First Name: Quenten
Mike, I think something like this would look very nice. Drill in from the side & router out a rectangle to fit, attach with 2 small wood screws.
Tonto1 is offline
post #20 of 43 (permalink) Old 01-07-2017, 01:32 PM
I googled floating shelves and came across some reall neat ideas .
Obviously it would only work in certain circumstances
TenGees likes this.
Human Verification
2x4 garage shelves help sonoramike Starting Off 12 01-08-2017 06:39 PM
Floating cubes. papasombre DIY and Renovation 12 07-18-2014 03:22 PM
Floating shelves mailee Show N' Tell 7 07-20-2012 07:36 PM
Floating mortise advice mah General Routing 12 01-24-2012 01:17 AM
Dado on 2 sides of 3/4 plywood for cubby shelves aquilja4 General Routing 3 11-06-2009 09:17 AM
