Floating Shelves - Page 4 - Router Forums
 61Likes
post #31 of 43 (permalink) Old 01-07-2017, 06:30 PM
old coasty's Avatar
First Name: Bob
Originally Posted by Everend View Post
Not "or something similar" use this kind only! All the others are a waste of time and money. I have used pretty much every anchor type available, for heavy things these are the only choice. For lighter weight drywall anchors use this style from Lowes https://www.amazon.com/TOGGLER-SnapS.../dp/B00ZSYPAX0 There is another brand that looks very similar to this but not quite as good. This one splits down the middle, so if you remove it from the wall you can reinstall it again. The other version (from HD) split half way up the shank making it not reuseable.
These are great when the load is straight down the wall such as a cabinet or shelf bracket. Once you get a single shelf, no bracket, the torque tends to pull out from the wall, not down. Have one with just a small portable phone, a pad and some pencils, that is drooping after 3 months.
old coasty is offline
post #32 of 43 (permalink) Old 01-07-2017, 06:47 PM
RainMan 2.0's Avatar
Mike these look just like yours . This isn't you 30 years ago is it?
I don't actaully know anything about CNC router tables , but I stayed at a Holiday Inn Express last night
RainMan 2.0 is online now
post #33 of 43 (permalink) Old 01-07-2017, 06:51 PM
MEBCWD's Avatar
Rick,
You can hide the money for your insulation in the hollow part of the shelf when you mount them so you know where it is when you get ready to insulate the shop!
TenGees and RainMan 2.0 like this.
MEBCWD is offline
post #34 of 43 (permalink) Old 01-07-2017, 07:03 PM
Originally Posted by MEBCWD View Post
Rick,
That's good thinking right there , but I think Nostradamus predicted the end of the World before I get my garage insulated . Well that's unless there's some extraterrestrial intervention
I found another one for MT to build
post #35 of 43 (permalink) Old 01-07-2017, 07:11 PM Thread Starter
MT Stringer's Avatar
Hmmm...not me. I was much more handsome than that dude!
RainMan 2.0 likes this.
MT Stringer is online now
post #36 of 43 (permalink) Old 01-07-2017, 07:15 PM
Everend's Avatar
First Name: Everend
Rick,
Put a little slot in the top to turn it into a piggy bank.
There is probably a really good joke in there about it being above the toilet ...
MT Stringer and RainMan 2.0 like this.
Everend is offline
post #37 of 43 (permalink) Old 01-08-2017, 01:14 AM
Hey guys , I could build it like this one and hide my insulation stash in there
post #38 of 43 (permalink) Old 01-08-2017, 08:22 AM
Knothead47's Avatar
Rainman, great idea for the end drawer. Thanks for googling the photo.
John T.
My wife gives sound advice. 99% sound and 1% advice.
Knothead47 is offline
post #39 of 43 (permalink) Old 01-09-2017, 10:27 PM
Everend's Avatar
First Name: Everend
Part of tonight's job is to refinish a bathroom counter top made from live edge solid wood. The sticker on the bottom side says it was made in India and looks to be salvaged from an entertainment center. This would explain why the finish didn't hold up to the water around the sink.
Above the coutner was a floating shelf supported along the back and 4" of one edge. They installed a 1/2"x1/2" ledger then glued the shelf over the ledger. Prying it off the wall destroyed the ledger and I'll need to clean the glue out of the dado.
Everend is offline
post #40 of 43 (permalink) Old 01-11-2017, 12:43 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Mike,
Nice and cute helper.
MT Stringer likes this.
We, woodworkers are everywhere!!!
papasombre is offline
Human Verification
2x4 garage shelves help sonoramike Starting Off 12 01-08-2017 05:39 PM
Floating cubes. papasombre DIY and Renovation 12 07-18-2014 02:22 PM
Floating shelves mailee Show N' Tell 7 07-20-2012 06:36 PM
Floating mortise advice mah General Routing 12 01-24-2012 12:17 AM
Dado on 2 sides of 3/4 plywood for cubby shelves aquilja4 General Routing 3 11-06-2009 08:17 AM
