Help
Go Back   Router Forums > Other > Show N' Tell
Two bracket clocks, an interesting project.
This is a discussion on Two bracket clocks, an interesting project. within the Show N' Tell forums, part of the Other category; Here I show two bracket clocks, of several that I have made, unfortunately, I cannot ...
Old 02-28-2009, 09:56 AM   #1 (permalink)
derek willis's Avatar
First Name: Derek
derek willis will become famous soon enough
Default Two bracket clocks, an interesting project.
Report Post Report This Post!
Here I show two bracket clocks, of several that I have made, unfortunately, I cannot give you W,I,P, pics because of a disc failure some time ago, a rough guide to the making is included, a popular concept I think.
Instructions for Oak Bracket Clock, Here Ebonised with VanDyke Crystals.
• Base and top finished 225x130, to protrusion, x 20mm.
Make a pattern out of 12 mm. m.d.f. attach to blank with hot melt glue, trim to shape on router table with bearing guided trimming cutter.
Form roman ogee to the edges. Make two.
• Cut sides two off, 225 x 80 x 12 plus enough to set into top and bottom
About 8mm..
• At 29mm centre from each side, groove base and top to receive sides, i.e. rout housing for sides, can be full width or as a rebated housing.
• Cut rebate into rear sides for rear access door, also groove for fascia, 9mm. at about 20mm. from face at front. (Fascia being clock face)
• Cut fascia panel either from solid oak or, as I did, from 9 mm. m.d.f.
225x175mm or to fit between assembled sides and into grooves.
• Assemble sides to base with p.v.a. top and bottom, glue fascia panel
Into grooves, and fit top to sides.
• Make a crowning piece to stand 12mm. inside moulding on the top, put a large round over onto this do not glue into place until handle has been fitted.
• Make a rear access panel to fit between the rebates, either hang this on brass butts or fit into place with rare earth magnets, it is only needed to access the battery.
• Prepare timber finished 20x15 for the front door, put a small rebate on the inside, round over both outside edges, cut to size with mitred corners and glue up, glaze with 2mm. glass set into clear silicone. Hang on pair of 25mm. brass butts, use rare earth magnet for closure, to fit magnet, tack panel pin into side, crop and close door onto it, remove pin, this will give you the position for the magnet and also, in the door, the position for a cropped headed tack, fit the tack by drilling small dia. Hole, place tack in hole and fix by squashing with pliers.
• Fit the brass furniture, glue on the top.
• Glue the clock face or chapter ring onto the front fascia panel and drill hole central for movement, fit movement.
• Seal and polish to your requirements, either Danish oil, or French polish with shellac, (my choice). (In reality any staining and finishing would be done before any fitting out would be carried out.)
• Here shown, one finished with ebonising by using Van Dyke Crystals, the other, in natural European oak, both finished with Shellac.
Derek
derek willis is offline
Old 02-28-2009, 12:01 PM   #2 (permalink)
curiousgeorge's Avatar
First Name: George
curiousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to behold
Derek,
Thank you for the post. Those are some beautiful clocks. I'm sure Harry will take heed as he has been known to make a clock or two.
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is offline
Old 02-28-2009, 12:13 PM   #3 (permalink)
levon's Avatar
First Name: levon
levon is on a distinguished road
hi derek,
complicated, clocks? you can push them or pull them." what more do you want to know"?
if they are in a circle you push, push pull pull. heck you can even slide them.
levon
levon is offline
Old 02-28-2009, 12:33 PM   #4 (permalink)
First Name: Derek
Exactly,
they go round don't they?
Derek
Old 02-28-2009, 01:06 PM   #5 (permalink)
First Name: Bob
Bob N is a splendid one to beholdBob N is a splendid one to beholdBob N is a splendid one to behold
Really nice work Derek! I have a clock fetish and have a house full, but yet to try my hand at making one.... YET!
You do good work friend!
a/k/a "Grumpa"
Bob N is offline
Old 02-28-2009, 07:14 PM   #6 (permalink)
First Name: Michael
GateKeeper is on a distinguished road
Beautiful workmanship Derek, I prefer the dark one but thats just me it looks more sophisticated. Very nice.
GateKeeper is offline
Old 02-28-2009, 07:59 PM   #7 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
Very, very nice Derek, as George has said, I went through a clock making period a few years ago, most were more basic than yours. This is just one example made well before I had a digital camera.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 03-01-2009, 02:32 AM   #8 (permalink)
RustyW's Avatar
First Name: Rusty
RustyW will become famous soon enough
Great clocks Derek. I also love building clocks. I've made so many, I now just give them away when I get done. They make great wedding gifts.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Old 03-01-2009, 03:29 AM   #9 (permalink)
First Name: Derek
Cheers,
Bob N
bob, does this mean you might be little bit cracked, (joke ha! ha!)
Derek
Old 03-01-2009, 05:27 AM   #10 (permalink)
First Name: Derek
Here are a few mor simple clocks, (the hands were removed for storage and transport to craft fairs), although some are weather instruments.
Derek
An interesting project Mike Tools and Woodworking 1 08-12-2005 09:28 PM
