Go Back   Router Forums > Other > Show N' Tell
Rate This Thread - Picture frames (process I use)..
Thread Tools Display Modes
Old 10-03-2005, 03:17 AM   #1
NewMontanaWorkshop
Forum Geek
NewMontanaWorkshop's Avatar
NewMontanaWorkshop will become famous soon enough
Default Picture frames (process I use).
Here is a link to one of my gallery pages that goes through the steps I use in making inlaid picture frames.
http://bt3gallery.fhauto.com/view_al...meSteps&page=1
Hopefully this might help someone in their frame building. I would like to hear from others that may have 'better ideas' also.
NewMontanaWorkshop is offline   Top - Reply with Quote
Old 10-03-2005, 08:52 AM   #2
Visteonguy
Forum Geek
Visteonguy's Avatar
Visteonguy is on a distinguished road
Nice Frames, Stan,,, you posted this just in time... I am taking a framing and matting class at work, near the end of this month and will have a lot of paintings to frame,, I may try your inlay method for some of them,,,, thanks
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline   Top - Reply with Quote
Old 10-03-2005, 10:38 AM   #3
NewMontanaWorkshop
Forum Geek
Terry,
That sounds like a very useful class. If you would, please update here with any tips and tricks you learn at the class that would be useful for all.
Old 10-17-2005, 04:13 PM   #4
deanj
New Member
deanj is on a distinguished road
Thumbs up
Stan
Nice frames! you make it look so easy. I was wondering if you would tell me what profile bit size and shape you are using to make the outside and inside profile. I am going to make some of these frames and need all the help I can get. Do you just glue the corners or use a biscut/spline to reinforce.
Dean
deanj is offline   Top - Reply with Quote
Old 10-18-2005, 02:46 AM   #5
NewMontanaWorkshop
Forum Geek
Originally Posted by deanj
Stan
Dean
Dean,
Here is a picture of the bit that I used for that set of frames.
Although I'd probably just use a 3/8" or 1/2" roundover bit for most of the stuff if I had one. I'd just use whatever bits I had handy and go from there.
The corners are splined to give additional surface gluing area as you can see in this picture.
I didn't like the finish on one of the frames so started giving it the '4 foot drop test'... Basically dropping it from shoulder height onto one of the corners on a carpeted floor. It lasted 42 times before a corner finally split apart.
Old 10-20-2005, 10:06 AM   #6
rh111
Forum Geek
rh111's Avatar
rh111 is on a distinguished road
I went to the gallery and viewed your process. You have refined it to an art. I was looking to make some frames, and I think that I have learned quite a bit from your gallery. Thanks for the info and the link.
It's all good till it's no good anymore.
rh111 is offline   Top - Reply with Quote
Old 10-20-2005, 02:17 PM   #7
NewMontanaWorkshop
Forum Geek
rh111, thanks for the comments. It's an ongoing learning process getting the frames (especially the miters) to come out consistent. I learn something new almost every time I make a new batch of frames.
I'll be updating the gallery the next time I run a batch as there are some additional hints that may help others -- and I'm still looking for suggestions if anyone else has anything to throw into the mix.
Old 11-20-2005, 04:54 PM   #8
moreorles2000
Dedicated Member
moreorles2000's Avatar
moreorles2000 is on a distinguished road
snowshoe
i visited your site & really learned quite a bit. i have never made anything with a router
& the step by step process really helped me. now i have an idea of how to at least give it a try. this board is really helpful to me especially for ideas & projects that have been made. i have the PC 6931 combo unit & i see now that it is not very powerful
but i figure it is good enough 4 me to try some stuff.i like the idea of people showing how to do different things & do's & dont's especially the safety tips. awesome board
people & keep up the good work.
les
moreorles2000 is offline   Top - Reply with Quote
Old 11-20-2005, 05:39 PM   #9
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
Mark is an unknown quantity at this point
Oh wow, those are some impressive frames. Very nice job Stan.
Mark,
Administrator and Technician of RouterForums.com
Contact RouterForums.com
Refer a friend to RouterForums.com!
Mark is offline   Top - Reply with Quote
picture frames unlimitedwoodworker Lobby 5 12-26-2007 12:25 AM
Locking mitre joints for picture frames grandsire02 Table-mounted Routing 3 08-10-2007 01:56 AM
Picture frames Glenmore Show N' Tell 6 07-09-2007 05:52 PM
cutout for picture frames and mirrors newbierouterguy Router Bits - Types and Usage 4 03-25-2007 06:56 PM
Need advice and guidance for routing picture frames popmoon Table-mounted Routing 26 03-11-2007 11:11 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
