Go Back   Router Forums > Other > Show N' Tell
Rate This Thread - router duplicator machine.
Thread Tools Display Modes
Old 10-30-2005, 11:27 AM   #1
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Visteonguy is on a distinguished road
Default router duplicator machine
I am putting the finishing touches on this machine I made,. I always wanted a full sized air plane propeller with a clock in the hub to hang on the wall,, and could never figure out how to form the blades of the prop so they looked real,,, and I stumbled on an article in a magazine about some guy that makes props for air boats,,, and over his shoulder was the machine he used to make them,,, so I searched on the net and found some machines and used a combination of them to come up with my version of a machnine,, While I was researching, I seen exhamples of projects that were being made in these machines, that I never dreamed of before,,, so this machine should be a ball to play with once its up and running.
The router is a porter cable purchased off Ebay. And I still have to fabricate the attachment that you will mount the pattern and your workpiece on, that will allow you to rotate them, both to the same degree, so you can duplicate just about anything in wood, in 3-D.
router-duplicator-machine-im002623.jpg  router-duplicator-machine-im002624.jpg
Terry
It seems like every where I go,,,,,,,,,,,,,,,,,,,,,,,,, there I am...
Visteonguy is offline   Top - Reply with Quote
Old 10-30-2005, 12:09 PM   #2
-Sam-
Forum King
-Sam-'s Avatar
-Sam- is on a distinguished road
Thumbs up
Wow, very interesting set up you have there. Nice job!
Sam
Retired Forum Moderator
Refer a friend to RouterForums.com!
-Sam- is offline   Top - Reply with Quote
Old 10-30-2005, 02:18 PM   #3
NewMontanaWorkshop
Forum Geek
NewMontanaWorkshop's Avatar
NewMontanaWorkshop will become famous soon enough
Terry,
'Very ingenious' design on your part. I have one if the sign carvers you are referring to as you based your design on.
If you need/want any other measurements off of mine -- feel free to ask away and I'll check on mine.
Again, good job on coming up with your own design. I think your way ahead in your design with the solid base yours sits on, that is one issue that I have with mine is the 'tabletop' flex's just a bit due to the weight of the slides and arms. A thicker top such as yours should take care of that though.
NewMontanaWorkshop is offline   Top - Reply with Quote
Old 10-30-2005, 02:45 PM   #4
Visteonguy
Forum Fanatic
Visteonguy's Avatar
Thank you Sam, and Stan. And, yes Stan, I did see your machine on the net,,it is a variation on the same theme. I made this so the router and stylis are exactly 15 inches apart, and will make a project about 4 feet long, ( in the case of the prop,, it will make a prop about 8 feet long by turning it end to end and carving one end at a time ) that would probably work for most situations,,, but now that I have it in the " real bones",, I am thinking I may make another one down the road, that will have a longer and wider table, to handle longer objects. like antique moldings and things like that. Have to fool with it a while and see if its really needed.
Terry
Old 10-30-2005, 04:11 PM   #5
NewMontanaWorkshop
Forum Geek
Sounds like a good plan Terry! I'm sure others would like to hear your construction methods and decisions -- looks like something I think others may want to tackle.
Old 10-30-2005, 10:08 PM   #6
kp91
Forum King
kp91's Avatar
Great looking project!
1 John 1:9
Old 10-31-2005, 07:17 AM   #7
GoonMan
Forum Geek
GoonMan's Avatar
GoonMan has a little shameless behaviour in the past
Thumbs up
WOW Terry it is looking Good. I like the set up. Time to make some dust fly.
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ Twin Oaks Mill
GoonMan is offline   Top - Reply with Quote
Old 10-31-2005, 05:45 PM   #8
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Terry looks really great. Keep us posted on the projects you come up with this. Endless possibilities.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 11-01-2005, 09:55 AM   #9
Julie
Forum Geek
Julie's Avatar
Julie is on a distinguished road
Cool, Terry! Wish I had your mechanical abilities.
Can't wait to see what you make.
~Julie~
Julie is offline   Top - Reply with Quote
Old 01-06-2006, 10:53 PM   #10
presumed_druid
Forum Fanatic
presumed_druid's Avatar
presumed_druid is on a distinguished road
Wow! I mean, just.... WOW!!
But the thing is, it's not 'wow' about the machine. It's about the passion you have for the project! It looks like there is no means that can't be justified by the ends.
A true example of ..... WOW!
presumed_druid is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
