| | #1 |
| Registered User Forum Geek | Aside from the simple things that I use a router for, this is the first real project that I have done with it. It took some time to get the hang of how it all goes together, but I did it and I am very happy. This is a jewelry/storage box that I made for my wife that sits on the dresser. I used a downsized raised panel set for 1/2" lumber. It was stained with a red oak and then a aerosol spray lacquer was used.
__________________ It's all good till it's no good anymore. Last edited by rh111; 06-13-2006 at 09:08 AM. Reason: Pictures Added |
| | #2 |
| Registered User Forum Geek | Ok, got pics to add this time!
__________________ It's all good till it's no good anymore. |
| | #3 |
| Registered User Forum Geek | Nice looking chest, keep up the good work. Regards Jerry |
| | #4 |
| Forum Contributer Supreme Forum King | Looks good rh111 Here's a tip, ask Jerry how to seal red oak so it comes out like glass,RedOak can be tricky to finish, Jerry is a Pro.when it comes to putting a finish on your projects. Bj ![]()
__________________ Bj |
| | #5 |
| Senior Moderator Supreme Forum King | Nice job on the jewelry box.
__________________ Mike |
| | #6 |
| Registered User Forum Fanatic | rh111...like Bob says, Red Oak being a coarse grained wood will often produce a splotchy appearance if the grain is not sealed. It is so coarse grained that often during glue-ups when clamped glue will often come to the surface outside of the joint. I have not tried it but have seen claims that if you take a short piece you can blow water through the grain & it will come out the other end. A good grain sealer is made by Benjamin Moore. Almost a paste & is rubbed into the grain with a piece of burlap. It will then take staining with a smooth continuous color. Following staining, if you want a fairly natural look, a mixture of semi-gloss varnish & 30% by volume naptha will give you a fast drying wipe on finish...usually 5 or 6 coats is applied. For a glass like finish use high gloss varnish & naptha. In any case that is a nice chest....keep up the good work. Lee |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 02:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
