| Show N' Tell Share your pictures of your latest projects with other members and visitors. Unfinished and finished project pictures welcome. Please give a small description of your project and what it was finished with. |
| | #1 |
| Registered User Sr. Member | My first time with walnut and my first project with my new table saw (and a straight fence!). I looked around online for plans, but didn't find anything that fit what I wanted, so I made my own. The basic design came from one of Norm's projects, but his was pretty plain, so I added some scroll work to the apron and the lid, and brought the drawers out to overlay the face frame. The top is a negative pattern of the apron, on a slightly larger scale. The design was laid out using Google Sketchup. I made the molding around the edge myself. Since I only had 3/4 stock to work with, I rabbetted the edges of the drawers so they only have a 1/2 profile from the face frame. What you don't see in the pics is the piano hinge and brass chain to hold the lid open at about 120 degrees that I have since added. the drawer sides are birch ply, and the top drawer is a false drawer, it doesn't pull out. I was going to put a mirror on the underside of the lid, but the wood was too pretty to cover up. Finished with dark walnut stain, a mixture of boiled linseed oil and polyurethane next, followed by a couple of coats of satin polyurethane. Just need some felt in the drawers and I'm all set. I think the drawer sides need some more stain as well, but I wanted to go ahead and post some pics. |
| | #2 |
| Registered User Forum King | A beautiful piece of work "R".
__________________ Pete I've cut it twice and it's still too short! But only at one end. |
| | #3 |
| Forum Contributer Supreme Forum King | Very Nice rpice54 What kind of bit did you use on the top ?, I know how hard it can be to get into the tight radius without burn marks, and to get the bit to make the cut true. Brand name,bit name,part number please thanks.Bj ![]()
| | #4 |
| Official Greeter Supreme Forum King Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 4,567 ![]() | Great looking project there Mr.Price. A fine job for first time. Looks professional to me.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. |
| | #5 |
| Registered User Forum Geek | nice job If you want to Flock the inside with suede here is a site that has any color you want I flock all my box's with it You can get it at different supplyers This is the co. This stuff work's easy and looks great http://donjer.com/suedetex/product.htm
__________________ del schisler |
| | #6 |
| Registered User Supreme Forum King | Beautiful job del I love the finish |
| | #7 |
| Registered User Sr. Member | thanks for the flocking info, I haven't yet decided exactly how to divide up the drawers, but the flocking sounds much easier than trying to apply adhesive and felt to the inside- how durable is it? I just don't want it pulling up after a year or two. as for the radius on the lid- I spent a lot of time trying to decide if I should take a chisel to the lid and square up the top profile to match the bottom- and then I decided my hand tool skills were not up to par and left it alone. as far as the bit goes, it's just a regular ogee bit- I bought a ryobi starter pack with 18 bits when I bought my first router. but I went very slow in getting to the full profile- shaving off little bits at a time and not going for a full thickness cut. I actually placed a larger radius bearing on the bit and worked my way towards that with 2 passes, and then changed to a smaller bearing, and took two passes to get all the way to it. The final pass ended up only taking off ~1/16 which allowed me to run through the profile pretty quickly and thus avoiding most of the burn marks, the rest had to be sanded out by hand. but I think it was more technique than bit, because it's certainly not a high end bit, but when a little patience is used I get good results from it. |
| | #8 |
| Forum Contributer Supreme Forum King | Thanks for the feed back rpice54 Have you tried the bits below they work great for tight radius... ![]() http://www.mlcswoodworking.com/shops.../bt_brass.html Again very nice job ![]() Bj ![]()
| | #9 |
| Forum Contributer Supreme Forum King | Hi rpice54 Can you PLEASE take a snapshot of the bit you used with the SMALL bearing on it, I have not seen one that small b/4 and I'm always on the look out for new bits. The only I have that small is a 1/4" flush trim bit with a 1/4" OD bearing on it. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 11-22-2006 at 10:19 PM. |
| | #10 |
| Registered User Sr. Member | sure, I'll do it when I get home |
| Walnut Burl Box Build Along (1st Veneer Project) | Nickbee | Show N' Tell | 38 | 03-18-2008 06:17 AM |
| Bleedback and walnut????? | Nickbee | The Finishing Touch | 4 | 02-21-2008 10:22 AM |
| Walnut Desk | rprice54 | Show N' Tell | 17 | 01-22-2008 07:48 PM |
| Walnut Burl Veneer… What kind of glue? | Nickbee | Tools and Woodworking | 7 | 01-19-2008 10:56 AM |
| Repairing Walnut Ply? | Nickbee | The Finishing Touch | 3 | 12-15-2007 06:17 PM |
