| Show N' Tell Share your pictures of your latest projects with other members and visitors. Unfinished and finished project pictures welcome. Please give a small description of your project and what it was finished with. |
| | #1 |
| Forum Contributer Supreme Forum King | Hi Harry Here are some snapshots I thought you would get a kick out of ![]() Or anyone that wants to make a jig for the Tom's/Harry Template way of using the Plunge Router... NOTE*** I'm still waiting for the Acme Threaded rod to use in the jig..about a week or so b/4 I get them, But the 3/8-24 NF all thread will work just fine. ======= Tom ▼ http://www.routerforums.com/guide-bu...te-guides.html Harry ▼ http://www.routerforums.com/guide-bu...ff-router.html Offset rings ▼ http://www.routerforums.com/49128-post1.html NOTE***** If you find the 3/8" slot a bit to tight for the 3/8" threaded rod chuck up a 3/8" router bit in your battery drill and rem the slot out just a bit so the rods just sides in easy....it only takes 3 or 4 times up and down the slot to get it done...then put a slot in a 3/8" dowel rod ( 4" long rod ,band saw a slot in one end to hold the sand paper in place) and rap it with a bit of sand paper (100 grit) to clean it up..,,,,.spin it with your drill.... http://www.routerforums.com/jigs-fix...ates-more.html Bj ![]() =========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-02-2008 at 11:07 AM. |
| | #2 |
| Retired Moderator Supreme Forum King | Ha ha .... going to make Harry happy. So I take it that the Acme stuff you got isn't all thread, just threaded on the end? So you think that will work ok then in place of the acme and did you get it locally at a hardware store? Corey
| | #3 |
| Registered User Forum Fanatic | Hi BJ, Doyle here. I have been following with great interest - the Jig and Acme Threaded Rods with the adaptation of wing-nuts on acme nuts. Thanks for the photos and all the information I have been gleaning from your posts. I do have an unrelated question; I need to purchase some good quality Forstner Bit, where should I buy them? Keep posting and I'll keep reading and learning. Thanks again, Doyle
__________________ Our tools and machines never take prisoners! |
| | #4 |
| Retired Moderator Supreme Forum King | Well, if you need a set and need them now... MLCS has some good ones. If you want a great set.... go Freud... their carbide forsteners are awesome and I used them to do clock fit ups with. They last for a long long time. I am still using a 1 3/8 one that i bought for fit ups and now I use it on the lathe as well. They are expensive but worth it! If you don't need a big set and just a couple I would look at freud. I also use a 3/8 Freud that I have had for a long time to do screw holes and plugs. Corey
| | #5 | |
| Forum Contributer Supreme Forum King | Hi Corey I still want to use the Acme All thread rod but I thought I would try and make Harry happy this weekend I should be Sunday or Monday when he reads this..![]() I got the 3/8-24 NF all thread from A & I Bolt in Denver,,same place that's making the Acme all thread, They dropped it off today,,, I did try and damage the threads but it was OK because it was fine thread and I didn't crank it down all the way....(the 2 wing screws on the router base) I should NOTE****the 3/8-24 x 3ft. all thread I got was full of plating so I did need to run the die down it so the nut would go on one of the rods ( see snapshot) but that's the norm for plated all thread, so to say if you are going to get some from HD/ACE/Lowes take a nut with you and check it b/4 you buy it, can save you a hour or so running die down it... I did chuck up the rod in a drill and clamped the die handle in the vise and got the job done quick....then cut it to size after... Bj ![]() Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-27-2007 at 03:01 PM. | |
| | #6 | |
| Forum Contributer Supreme Forum King | Hi Doyle Thanks "Forstner Bits" = you can get them from eBay,Grizzly,MLCS, etc. BUT like most cutting tools you get what you pay for....I buy 2 sets at a time from eBay because I know I will cook them,,, they are cheap about 12.oo set 1/4" to 2 1/4" and I also have the big set from 2 1/2" to 4" they are a bit better or to say I don't use them all the time like the small set...Once you heat the bit up that's it ,,,,tent stake,,,,,and I do it all the time...I use alot of MDF and it's hell Forstner Bits..... ![]() Bj ![]() Quote:
| | #7 |
| Forum Moderator Supreme Forum King | Bj, Great job and I really appreciate your sharing this with us. I have a lot of interest in this method of routing and want to give it a shot after I finish absorbing my learning curve in the various areas I am already involved in. I have bookmarked this thread for future study and look forward to making the jig you have pictured when the time comes. Thanks for establishing a jig we can all make and use on our side of the planet. Now... if I can just get the metric system figured out ![]()
__________________ Cheers, Bob |
| | #8 | |
| Forum Contributer Supreme Forum King | Hi Bob Thanks,,,,,and you'er welcome, enjoy,,,,I think I got it figured out ( metric system ) just take your shoes off and use your ten toes and ten fingers and don't count the gaps between them.... something like they have been doing down south ( in GA.) for a long time but just didn't know they had it down along time ago.. ![]() Bj ![]() =============== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-27-2007 at 09:07 PM. | |
| | #9 | |
| Retired Moderator Supreme Forum King | Quote:
I expect he's a grumblin now..... Damn Yankees!! he he heCorey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #10 |
| Senior Moderator Supreme Forum King | BJ, a super job. I know Harry will be surprised and I think Tom would sh.. er, um, defecate a canary.
