Go Back   Router Forums > Other > Show N' Tell
Show N' Tell Share your pictures of your latest projects with other members and visitors. Unfinished and finished project pictures welcome. Please give a small description of your project and what it was finished with.
Thread Tools Display Modes
Old 11-12-2007, 07:28 AM   #1
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Default My 1st Box w/inlayed joints (Build Along)…
I’ve done build along threads for my RC airplanes before. I enjoy them. You guys can watch my progress, tell me how to do things better / easier, and I can ask questions.
To tell you the truth it’s the 1st box I’m making with kind of joint (besides a but joint). It will be a simple 7x7x3.5 box with an open top and a cork lined bottom for tossing keys / change into.
Now I’d love to tackle a nice inlayed fingered or dovetail joint. But since my router table set up is an “in progress” project I’m limited to my old table saw for making some joints. So I’m going to start with a simple dado joint (I think that’s what this joint is called, correct me if I’m wrong) cut a little larger to accept a 1/32 inlay.
Like most of my projects this one starts out with a pad, pencil and lots of coffee.
I racked my brain for a while figuring out how place the inlays and how it effects my dado measurements. I seriously need to learn how to use sketch up one of these days.
Here’s the raw wood. A nice piece of poplar from Lowes and sheet of 1/32 walnut from my hobby store.
I’m liking the grain of the poplar. And the walnut should provide a nice contrast for the inlay.
Off to the power tool I have to relay on for my cuts / dados. A table saw that is most likely twice as old as I am. To give you an idea of how old this “hand-me-down” from my father is… This saw was given to him 30 years ago from the printing company that we worked for. They used it years before that for cutting lead printing plates! I have to look at the labels closer one night and see if I can find a date of manufacture on it.
The good news is that it’s solid and has a decent guild that “clicks” as you twist it. It actually makes decent dados. One day I need to adapt some kid of fence for ripping as now I use an angle iron and a few claps (gets the job done in a pinch).
But no ripping today. Since the wood from Lowes is 3.5” I’m going to make the box sides 7” to give a pleasant “half cube” appearance.
As I cut I keep the wood in order and mark what will become the outsides and bottoms of the box. This should allow the grain to “flow” around the box.
As seen in the mock up:
Then it’s back to the saw to set the blade height per my drawings:
And then I start cutting my dados. Pass by pass on the blade.
The results are pretty precise. And if I’m off by a few thousandths of an inch I figure I’ll have some wiggle room with the inlays. And when all else fails there is always sandpaper!
Another mock up after cutting 2 pieces shows my design looks about right. With the inlays in the joint I should have a 90 deg angle.
Next I cut some inlays. I mark the “clean” edge with an arrow. This will be used to glue them in the proper orientation.
After doing some head scratching I figure out the best way to start gluing the inlays. The game plan is to use the clean edge against the inside of my cuts. Then cut / sand the inlay’s overhang flush with the wood after gluing. This way I don’t have to go crazy cutting precise inlays. Will it work? Stay tuned…
Here’s my magnetic building board in action. My 90 deg jigs hold everything tight while the glue sets. I’m using Titebond II because it’s what I had around. It was either that or epoxy. Figured wood glue for wood. But if there’s something better I could use for the rest of this project let me know.
Here’s a close up of the overhang:
This will sit for a nice 24 hour cure. I’ll report more as I make progress. But I’m not sure how much I’ll get done this week since I also have a project I need to finish varnishing. I can’t make dust while that’s going on.
Nickbee is offline   Top - Reply with Quote
Old 11-12-2007, 08:49 AM   #2
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Nick,
Being a box nut, I look forward to following your work-a-long.
Thanks for sharing with us.
Cheers,
Bob
Bob is offline   Top - Reply with Quote
Old 11-12-2007, 10:55 AM   #3
Nickbee
Forum Geek
Nickbee's Avatar
No problem Bob. Since you're a box nut can you recommend a finish? I want something satin (natural, no stain) that brings out the grain. I'm familiar with brush-on poly but would like to start exploring other finishing techniques...
Thanks!
Old 11-12-2007, 11:13 AM   #4
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
I've just started using Tung Oil. Brings the grain out beautifully.
http://www.routerforums.com/attachme...-100_2464s.jpg
AxlMyk is offline   Top - Reply with Quote
Old 11-12-2007, 11:31 AM   #5
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Thanks!
I like to build up a gloss poly finish or a tung oil poly mixture and let it cure for several days and then rub it out with 0000 steel wool and paste wax. Leaves a beautiful satin finish that is great to the touch.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 11-12-2007, 03:29 PM   #6
Nickbee
Forum Geek
Nickbee's Avatar
For finishing something that is not flat (like a box) is it better to use wipe on finishes to avoid drips?
Old 11-12-2007, 04:00 PM   #7
challagan
Supreme Forum King
challagan's Avatar
Well I don't know about better but I think it is easier Nick. Lots of finishes out there to use though. Shellacs', poly's, wipe on poly, lacquer,. Another good wipe on finish is Danish oil.
corey
Old 11-12-2007, 04:09 PM   #8
Nickbee
Forum Geek
Nickbee's Avatar
gotcha. I'd like to try something besides brush on Poly just to get experience with something different. When the time gets closer to finishing I'll pick your brains...
Old 11-12-2007, 04:51 PM   #9
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Nick,
I have had really nice results with a coat of Danish oil, let dry 24 hrs and then a coat of General Finishes Seal-A-Cell followed by another 24 hr dry. After that the Gereral Finishes semi-gloss wipe on poly of 3-4 coats with the final process as Corey described using steel wool and wax. It has worked excellent and I get lots of praises on the finish from the receivers.
Cheers,
Bob
Old 11-12-2007, 05:09 PM   #10
Nickbee
Forum Geek
Nickbee's Avatar
Great stuff Bob! I will pick your brain once I get close to finishing. Like I said earlier this project will be in a holding pattern for the next week or so while I finish up another project (a yarn swift for a friend). I will also post photos of that project once it's complete.
Thanks again!
Stained Glass Accent Lamp Build Along… Nickbee Show N' Tell 29 11-07-2008 06:46 PM
Incra Ultra How-To (Box Joints + Other Stuff) Nickbee Show N' Tell 5 01-21-2008 09:14 AM
Best bit for tight fitting box joints? Nickbee Router Bits - Types and Usage 9 12-31-2007 01:13 AM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 11:20 AM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 09:00 AM
