| | #1 |
| Registered User Forum Fanatic | First off, a huge thank you to you guys! Without your patience, I'm sure many more wood working novices would fall by the roadside, myself amongst them. So thank you all. Now, she who must be obeyed, wanted darker cabinets and draws in the bathroom to compliment the ongoing renovations(guess who's got that job as well!) I priced up both MDF covered and solid wood, the Oak was averaging about $55 for the doors and almost $30 for the draws. So far my material cost is working out at about half that. Clearly the labor cost is where I'm saving, but my time is free right ![]() Started off with 1/2" oak veneer ply and 2 1/2" x3/4" oak frame pieces. Ripped the frame down to 2 1/4" and using a T&G bit made up the frames. T&G was not the first choice but the wife likes the clean look. Cut the ply to size and then using a dado blade on the TS cut a 1/4"x1/4" dado all round to drop into the frame. More pictures to follow as I finish them off but I'm so pleased with the results so far. I'm not kidding myself that it in any way compares to the outstanding work I've seen on here by others. But this is my first "real" piece of finish woodwork since school! Not including rough carpentry for trim work and such. |
| | #2 |
| Registered User Supreme Forum King | Looking good. All it takes is a lot of practice and patience so the next time it will be easier and better. Keep us posted on your progress.
__________________ George If you can't fix it with a hammer, you've got an electrical problem... |
| | #3 |
| Forum Contributer Supreme Forum King | Looks good David Now your having fun with your router ![]() ===========
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #4 | |
| Registered User Forum Fanatic | Quote:
As far as a finish goes, I was thinking a dark stain and then a coat or three of spray poly? as it will be going from dry to humid often? Also, I've left the panel loose in the frame, I don't mean flopping about, but not fixed is that right? | |
| | #5 | |
| Forum Contributer Supreme Forum King | Your right on David "flopping about" = they should move just a bit, here's a tip, pickup some thin insulation about 1/4" x 1/4" cut it into 1" long strips, place them in the slots.. "stain" = stain the panels b/4 you glue them up,,, it's hard to get in the corners after you have them glued up not to say anything about the glue push out in the corners,,that will act like a wood sealer and then show up as boltch in the stain job...========== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 01-12-2008 at 07:25 PM. | |
| | #6 | |
I'll know on the next one | |
| | #7 |
| Registered User Forum King | Space balls could also be put in the grooves before inserting the panels. Little round balls of rubber that squish in to keep the panels from rattling.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #8 |
| Forum Contributer Supreme Forum King | Looking good David.
__________________ Harry |
| | #9 |
| Registered User Forum Geek | looks great!!!! I'm starting a similar project soon for a friend's small kitchen. Since they will paint the doors I'm going to use poplar rails / stiles and birch ply panels. I might start with some sample doors this weekend. |
| | #10 | |
| Registered User Forum Geek | Quote:
Regards Jerry | |
