| | #41 |
| Forum Contributer Supreme Forum King | Yes Ed., I was referring to the tops, normally these spikes would go into thicker material and surplus thread cut off so the hole would not go all the way through but If I were in your position I'm sure I would make wood domes to fit on top. Beneath the dome could be inserted a rubber grommet with a centre hole that's a push fit onto the excess thread. If you don't understand what I'm on about, don't hesitate to let me know and I'll attempt to make a mock-up to show you. I've just had another idea, chrome dome nuts, I think they would be quite sexy!
__________________ Harry |
| | #42 |
| Forum Contributer Supreme Forum King | Hi Ed Just a butt in post, I think he is saying to hide the top of the post (pin) Like below http://www.routerforums.com/74961-post11.html showing, In this case less is more.. But now that you have this type installed I would cut off a small bit of the stud and pickup some push in caps plastic or brass, the type you see on some furniture to hide the fastners... that would clean up the stands..=======
| | #43 |
| Registered User Forum King | Thanks guys, I will try to impliment some form of 'hidden' agenda for the spikes. Ed......:-) |
| | #44 |
| Forum Contributer Supreme Forum King | Hi Ed This is would I would do to clean it up just a bit, take out the threaded inserts and install them from the bottom side, but 1st. cut off the unthreaded ends of the spike points, then install some plugs, I would say put in some wooden dowels but they will show up like a sore thumb,it's hard to hide them.., I don't think I would use cap nuts on the studs they will become dust bunnies hooks over time, you want something clean and smooth so the duster can just fly right over them.. =====
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-17-2008 at 08:55 PM. |
| | #45 |
| Senior Moderator Supreme Forum King | Ed, I would cut off the threaded section with a small cut off wheel on a hand grinder. Apply a dab of black brushing lacquer with a Q tip and call it done.
| | #46 |
| Forum Contributer Supreme Forum King | Ed, this quick mock-up is to illustrate what I had in mind, try to imagine the correct dimensions. As chrome nuts are expensive, the cheap Nickel plated ones can be painted any colour you like.
| | #47 |
| Registered User Forum King | Thanks all for the suggestions. I guess this week I'll go about finishing the stain and then see what I can do about these extensions. Thanks again for all the possible solutions. Ed......:-) |
| | #48 |
| Registered User Forum King | Hi Folks, Well, finally got back into the shop. It's just been so busy at work and home the shop has almost become a forgotten entity....very little time. I'm now finishing up the speaker stands and though I've made many mistakes during it's making, they are finally coming to a close. I tend to agree with John that I don't like finishing work, but I'm learning about it anyway. I suppose it will grow on me. Anyway a few pics of the progress and in one more session should put it all to rest for the final time. Enjoy the pics and thanks again for having a peek. Ed......:-) |
| | #49 |
| Forum Contributer Supreme Forum King | Doesn't that look better Ken, I'm sure that you're very happy with the final result.
| | #50 |
| Forum Moderator Supreme Forum King | Ed really nice job on these stands. Really like the glossy finish on them. ![]()
__________________ Glenmore Days without wood working are days not worth getting up for. |
| transplanted from speaker building | loninappleton | Introductions | 8 | 07-01-2008 11:39 AM |
