Adhesive & Paper dulling bit? - Router Forums
 21Likes
post #1 of 16 (permalink) Old 02-15-2017, 10:11 AM Thread Starter
Does anyone know if routing through a glued down patten will dull a bit faster? I have always transferred the pattern with carbon paper, but the alternative sure would be a time saver.
Thanks in advance ...
Floyd .. Harrison Arkansas
BobbyLee likes this.
fdcox is offline
post #2 of 16 (permalink) Old 02-15-2017, 11:00 AM
Semipro's Avatar
First Name: John_*
I am sure it does by it would be minimal, plywood is full of glue, buy good bits and sharpen them.
Semipro is online now
post #3 of 16 (permalink) Old 02-15-2017, 11:55 AM
First Name: pat
Don't understand why you would route through a pattern (patten?).
But if you did, the wear on the cutter would depend on the depth of cut and number of copies.
A few here and there, no problem.
Quillman is offline
post #4 of 16 (permalink) Old 02-15-2017, 12:07 PM
JOAT's Avatar
First Name: Theo
You rout thru the pattern? Or the paper to the edge of the pattern?
Not enough to say, I would think. I rout plywood for almost all of my projects, and no issues. Wear on a router bit, in my experience, seems to depend mostly on what brand I am using, I try to stick with high quality bits, unless I need a bit right now, then I pretty much take what I can find locally..
I don't rout glued down patterns, I cut them out with my scrollsaw, then sand to final shape. But this is how I make my masters - glue the cut out pattern to another piece of plywood, use the first one to rout the glued on piece, and that gives me a 1" thick master - which is what I use to rout out pieces.
Hutzul and BobbyLee like this.
NC via the Army in 1979; retired 1981, just east of Raleigh ever since.
Remember, when I tell how I do something, that does not mean I recommend you do it my way. Different backgrounds, experiences; what works for me, may not for you.
No point in believing in things that exist. If they exist, you don't have to believe, they just are.
JOAT is offline
post #5 of 16 (permalink) Old 02-15-2017, 12:33 PM
I think the OP is talking about free hand routing signs. I have never done that, but I see on the forums a lot of guys using adhesive patterns to do signs.
Herb Stoops is offline
post #6 of 16 (permalink) Old 02-15-2017, 01:29 PM
I've printed out patterns on the computer and then glued them down. I usually do like Theo and cut and sand but routing shouldn't be an issue. I strongly recommend Lee Valley's Fish Glue for this. It stays water soluble forever so when you want to remove whatever paper is left you just spray it with water, wait a minute, and then peel it off. The residue wipes up with a damp cloth. Lots of uses for fish glue.
post #7 of 16 (permalink) Old 02-16-2017, 08:49 AM Thread Starter
This is for freehand routing, I should have mentioned that.
Herb Stoops and BobbyLee like this.
fdcox is offline
post #8 of 16 (permalink) Old 02-16-2017, 08:49 AM
First Name: Don
Floyd,
I would suggest that you checkout "Routerforums.com". You will definitely find the answer for your question there.
retired92 is offline
post #9 of 16 (permalink) Old 02-16-2017, 10:15 AM
vchiarelli's Avatar
First Name: Vince
Originally Posted by retired92 View Post
Floyd,
Am I missing something? His question (and your suggestion) are both on Routerforums.com.
Herb Stoops likes this.
Either lead, follow, or get out of the way.
vchiarelli is online now
post #10 of 16 (permalink) Old 02-16-2017, 10:22 AM
MEBCWD's Avatar
Floyd,
The only thing I would watch out for is build up of glue on the bit. You want to use a glue that won't burn and build up on the bit, this will heat up the bit and loose the temper dulling the bit quicker. The chips of wood removed normally carry the heat from the bit with then keeping the bit cooler. Keep the router moving so it is always cutting, if it spins in one spot too long it heats up the bit.
The big thing in doing signs free hand with a router is practice, practice, practice. Have fun with your signs.
MEBCWD is offline
Human Verification
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Router Bit Accuracy Mike Wingate Router Bits - Types and Usage 8 06-24-2009 12:38 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
