Help
Go Back   Router Forums > Routers > General Routing > Sign Making
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the oldest and largest router and woodworking community on the web! Join in over 29,500 discussions with over 65,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Making wood signs
This is a discussion on Making wood signs within the Sign Making forums, part of the General Routing category; Interested in learning how to make wooden signs with a router. would like to find ...
Old 12-11-2010, 10:06 PM   #1 (permalink)
rustysaw's Avatar
First Name: Blaise
rustysaw is on a distinguished road
Default Making wood signs
Report Post Report This Post!
would like to find out if anyone has a template in script lettering.
I have a turnlock signpro from rockler,but is very limited in it's use.
Also need help making different types of template's used in
sign craft.
thanks.Rustysaw
rustysaw is offline
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community!
Old 12-12-2010, 09:31 AM   #2 (permalink)
Ralph Barker's Avatar
First Name: Ralph
Ralph Barker is on a distinguished road
The only commercial sign templates I've seen have been simple block letters, due to the limitation of the template needing to be a single, continuous structure. For a script-style "font", I think you'll have to go free-hand, using printed letters glued to the surface as guides.
One of the problems with free-handing is having sufficient surface for the router base to rest upon. An over-sized base, or skis, can help in that regard.
- Ralph
Ralph Barker is offline
Old 12-12-2010, 10:11 AM   #3 (permalink)
Cassandra's Avatar
First Name: Cassandra
Cassandra is on a distinguished road
Hi Ralph:
Actually, the limitation of the template is not to be a single, continuous flow. The concept of multipositioning the basis of the Milescraft template system.
http://www.milescraft.com/product/1207.html is a link to the Milescraft product for pattern making. It demonstrates the use of multi-positioning templates. The same technique could be used for script lettering.
An aside: While looking the link, my computer tripped up on a very nasty malware link. Fortunately my anti-malware software did its thing. I rebooted the computer and re-scanned. All clean.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
Old 12-12-2010, 10:47 AM   #4 (permalink)
Cassandra's Avatar
Hi RustySaw:
Welcome to the Router Forums!!
If you're getting into sign making on a serious basis (like doing it as a business), you might want to invest in something like the Milescraft 3DPantograph (Milescraft - Universal Power Tool Attachments & Accessories - Routers - 3D Pantograph). Using this one could create one's own letter templates and then use those templates to make signs.
Just an idea.
Cassandra
Old 12-12-2010, 11:51 AM   #5 (permalink)
bobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant futurebobj3 has a brilliant future
Hi Cassandra
Thanks ,I forgot ALL about the FREE patterns (templates)
http://www.milescraft.com/service/1298templates.html
Originally Posted by Cassandra View Post
Hi RustySaw:
Just an idea.
Cassandra
MANY,MANY help files on John's web site
http://legacy.woodshopdemos.com/menu2.htm
Sommerfeld Tools ,Videos
Old 12-12-2010, 11:58 AM   #6 (permalink)
Cassandra's Avatar
Hi Cassandra
You're very welcome, Bob!
Those templates are just for starters, right? One can always make one's own. For example, go into MS Word, look up a font one likes and then type in the letters one needs. After adjusting the FONT SIZE to an appropriate size and after putting reference marks (for example, underscores), print out the letters.
The attached PDF file contains a sample of what can be easily accomplished with something like Word. Font is 480 pt Segoe Script.
Cassandra
Old 12-12-2010, 12:14 PM   #7 (permalink)
Cassandra's Avatar
Rusty Saw:
Script Fonts @ 1001 Fonts .com
Same true type script fonts -- some freeware, some shareware. (I haven't downloaded any, yet.)
Cassandra
Sponsored Advertisements. Register to disable this advertisement.
Old 12-12-2010, 12:25 PM   #8 (permalink)
Cassandra's Avatar
Default Downloaded Font Sample
Here is the PDF of the sample letters, using the Precious font at 360 pt.
Cassandra
Old 12-12-2010, 02:34 PM   #9 (permalink)
rustysaw's Avatar
First Name: Blaise
Default wood signs
thank's for the info,problem is I am not that good with a router freehand
on lettering,will need a lot of practice. I also have a lot of time to get better.
Blaise
rustysaw is offline
Old 12-13-2010, 03:34 PM   #10 (permalink)
Travelin Joe's Avatar
First Name: Joe
Travelin Joe is on a distinguished road
Don't sell yourself short, I am also a newbie and my wife tells me that sometimes my freehand stuff is better than the things I stenciled and then routed. Try it on some old or bad pieces of wood, you may be shocked. It may also help is you just box you lettering for spacing and size and then free hand between the lines. Good luck.
Travelin Joe is offline
Tags
sign-making with a router
wood residential and business sign routing with mark disaverio General Routing 8 07-30-2009 08:53 PM
making new wood turn grey like old barnwood agravation Introductions 6 03-30-2009 06:29 AM
Making signs with a router mbrull Sign Making 0 12-03-2008 10:55 PM
