Raised letter signs - Router Forums
post #1 of 4 (permalink) Old 05-11-2006, 10:47 AM Thread Starter
First Name: Don
Raised letter signs
I am making raised letter signs. I am using a trim router from homier and a straight bit. My problem is the bottom of the sign has trails and is uneven. Am I using the wrong bit if so what should i use? I am new to woodworking and any info would be greatly appreciated.
dleveque is offline
post #2 of 4 (permalink) Old 05-11-2006, 11:28 AM
Dleveque
You may want to drop a email or PM to Alan (mailee) for a tip or two looks like he has it down right.
see link below ▼
http://www.routerforums.com/showthre...ghlight=mailee
Bj
post #3 of 4 (permalink) Old 05-11-2006, 02:18 PM
For this application an upcut spiral bit would give a better finish. This type of bit has cutting edges on the end of the cutter where a straight cutter does not. Another consideration is providing enough support for your router base so it will ride evenly.
post #4 of 4 (permalink) Old 06-03-2006, 10:38 AM
Wink
Dleveque
Just a add on Note***
Don't forget the Table Top Jig Saw/Scroll Saw, you can cut the letters or numbers out and then glue them in place. (with a good outside glue,T-Bond)
Or cut all the numbers and names as one item ,this will give it the look of free cut with a router . (Raised Letter Sign)
Bj
Human Verification
Question on raised panels kylawyer Table-mounted Routing 8 03-24-2011 01:29 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 08:20 PM
Raised Panel Vertical or Horizontal Sets? WoodyRon Router Bits - Types and Usage 8 11-24-2007 03:54 PM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 11:34 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 10:47 AM
