New raised letter door sign - Page 3 - Router Forums
post #21 of 35 (permalink) Old 10-16-2012, 04:06 PM
OutoftheWoodwork's Avatar
First Name: Barb
Originally Posted by L Town Graphics View Post
John, I'll try to answer each one of these as best as i can. if something i write doesnt make sense lmk as i can try to explain further
1. all of my router "strokes" are either towards me or across. almost all of my works I end up flipping upside down to assure i have gone to the edge of my pattern on the top.
2. this one is kinda interesting. I don't think i've ever gone more than 1/4" deep on any of my signs. what keeps it from jumping.... firm grip on the router? the only time i really have had to focus on not letting the router jump is when i use a corebox bit..... hold on tight cause it will jump if you let it. the choices of wood i have used so far are pine cedar and oak. I have not used anything else to this point.
3. i think it has helped me alot because im not looking for a pencil line, think of like an old school snowflake that you made in school. so you cut it out of the paper made your other cuts inside held it up and whala! when i lay a vinyl stencil down it gives me clear patterns and view of the wood i need to route.
4. I just posted two pics in the sign a day thread. one was the computer layout on my graphic design program and the second is the finished product. I did that piece in about two hours routed and painted. Keep in mind I have all the tools of most sign shops in your area at my house. when i get the layout the way i want it, my plotter cuts the stencil for me. I remove the parts that i want to route. I place the stencil on the piece of wood choose my bit and away I go.
5. I use two different routers PC model 1001 i think it is and a skil i bought from walmart. I use the PC the most because its a better tool but I don't choose one over another because of a specific bit or anything.
6. if i'm correct niether is a variable speed, no dials on either to adjust the speed
7. my biggest reoccuring problem is chipping an edge every now and then when i lift the bit. I have the tendency to tilt the router instead of coming straight up with it.
hope this helps! lmk if i can elaborate more on something specific
Dan, I keep seeing you post about Vinyl Stencils Can you post a picture of one? Do you create a stencil for every sign you do? If so where do you get it how do you cut it out, etc etc etc? Also, I see you made a reference to color. When using colors what do you use?
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is online now
post #22 of 35 (permalink) Old 10-17-2012, 12:49 AM Thread Starter
L Town Graphics's Avatar
Barb, the pics below are all signs I have made using a vinyl stencil. Pics in order stencil and finished piece of work, so you can compare. My reference to color was primarily the paint (if it was something else ill be glad to clarify). but as far as paint I use acrylic and hand paint almost everything now.
this sign is actually in front of my parents house
this one hangs at our hunting camp
this was a learn by doing, dont use plywood! so I glued some cedar to do the finished piece. I believe it was 4 or 5 26" pieces
"the last person that was perfect was crucified"
Find all of my work both wood and vinyl on Facebook
-coming soon- www.ltowngraphics.com
L Town Graphics is offline
post #23 of 35 (permalink) Old 10-17-2012, 05:36 PM
Your signs are made excellently. Keep them coming.
Camero68 is offline
post #24 of 35 (permalink) Old 10-17-2012, 06:39 PM
Gene Howe's Avatar
First Name: Gene
Wow! Steady hand, for sure. Nice work. The finished sign is very nice.
Ted- I used that wood because it was a sample piece a guy from the local mill gave me. He suggested it over the cypress I was there to purchase.
Don- no skis or anything, just my hands on the router. For me anyway the fewer gadgets the better. If you seem my "workshop" you would probably laugh. There isn't much to it, let alone it looks like a bomb went off in it from all the dust to small pieces of wood "strategically placed" pretty much everywhere.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #25 of 35 (permalink) Old 10-17-2012, 10:32 PM
First Name: Barb
[QUOTE=L Town Graphics;305075]Barb, the pics below are all signs I have made using a vinyl stencil. Pics in order stencil and finished piece of work, so you can compare. My reference to color was primarily the paint (if it was something else ill be glad to clarify). but as far as paint I use acrylic and hand paint almost everything now.
All I can say is "WOW!" Nice work! Acrylic? really? I haven't been able to get a good look with acrylic, and it's so time consuming. Ok... how are you creating your designs, and getting these templates in vinyl? What program(s)/devices are you using? Love your business sign... (I screwed mine up trying to update it yesterday; oh well I wanted a new one anyway lol)
Barb
Mark Twain
Henry A. Kissinger
post #26 of 35 (permalink) Old 10-18-2012, 12:46 AM Thread Starter
[QUOTE=OutoftheWoodwork;305216]
yes acrylic, any mistakes come off with a little sanding. I create everything in a design program called omega 4.0. Sometimes I start with a drawing (which i seem to be doing more) then I open the program and design it again there. Once my design is made I have a vinyl cutter which cuts the stencil for me. after that i remove the parts I want routed and place an application tape over the stencil to hold and free floating pieces in place (example the inner part of round letters like and e, a, o, the loop of a l, etc). after the application tape is applied i remove the backing from the vinyl (the paper part) and apply to my wood using a squeegee (see the first pic, the yellow looking square with the brown l town sticker on it). once its on i remove the mask as start routing. after all of the routing is complete and all debris are removed i paint it with the stencil still on. once the paint dries, remove the stencil and apply finishing coats. I have a sign to make this weekend once its finished i'll post pics, design view, masked, routed, painted and finished.
post #27 of 35 (permalink) Old 10-19-2012, 08:30 AM
First Name: Barb
I'm Jealous and can't wait to see the sign you make this weekend... will have to investigate your stenciling, because I need to find a better way, and really like the idea; looks like a real time saver.
Barb
Mark Twain
Henry A. Kissinger
post #28 of 35 (permalink) Old 11-01-2012, 08:52 AM Thread Starter
It is for sure! I hate tracing onto wood, lines are never straight curves seem to never follow the right arc..... This way it's machine cut and all I have to do is lay down the vinyl and get at it
post #29 of 35 (permalink) Old 11-01-2012, 02:28 PM
First Name: Barb
I need a "Like" button on here for when I agree with someone... LOL The vinyl and program will have to wait, unfortunately till I get everything settled with replacing all my tools that were stolen last weekend. Still trying to sort through all the stuff missing and putting on the forms, etc. But it's on my list to take care of, for sure!!!
Barb
Mark Twain
Henry A. Kissinger
post #30 of 35 (permalink) Old 11-01-2012, 05:20 PM
First Name: Bryan
Very, very nice work.
WhatDoIKnow is offline
Human Verification
Raised Panels: Router vs. Table Saw??? PorterCable690 Jigs and Fixtures 77 03-03-2014 08:34 AM
1/2" Stock for Raised Panel rdlorenzo Router Bits - Types and Usage 5 11-19-2010 10:00 AM
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 10:11 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 08:20 PM
Raised letter signs dleveque Sign Making 3 06-03-2006 10:38 AM
