| This is a discussion on What kind of wood for routing signs within the Sign Making forums, part of the General Routing category; What kind of wood is the best to work with for a beginning sign maker? ... |
| | #1 (permalink) | ||
| Registered User ![]() |
What kind of wood is the best to work with for a beginning sign maker? I need to figure out what wood I can use that isn't gonna give a bunch of grief & is pretty commonly available @ a local Lowe's or Home Depot. I will be using a template for recessed routing on boards approx 5' long. Thanx! | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
| Forum Liaison ![]() |
As a rule pine will be the cheapest, but the best choice would be cedar. Fewer knots, a soft wood that routs easily, still low in cost. It doesn't get much better than that.
__________________ Mike "Living in the D" (this means Detroit!) "It's fine to disagree with other members as long as you respect their opinions" | ||
| | #4 (permalink) | ||
I am guessing you are making free hand letters and not using a lettering jig? Your best bet would be to do your clean out with a dish cutting bit if possible. They make these in a 5/8" diameter and they will provide a clean level surface.
| | #5 (permalink) | ||
thanx for the response Mike. I am using a lettering jig to do recessed letter and seem to get some "burring" when going against the grain. I have found it very time consuming to try to smooth these out by hand with sandpaper. any suggestions? | ||
| | #6 (permalink) | ||
To deburr the bottom of routed in letters or the edges of raised letters use a 100 to 120 grit diamond bit in a Dremel. | ||
| | #7 (permalink) | ||
Pine is prone to leaving hairy burrs. Western red cedar and redwood are usually good choices but the wide grain, second growth is harder to carve freehand than old growth and is also prone to burrs but not as bad as pine. Old growth, with tight grain is harder to find and expensive. I try to stay away from old growth because I don't want to contribute to the logging of the last few remaining old growth forests. I used to use old growth redwood extensively for freehand signs. It's a dream to route. | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | ||
| Retired Moderator ![]() |
One technique I have used to get rid of the hairy burrss when routing recessed letters into pine was to run it through a planer afterwards set for a very shallow cut. In my case I wanted the recessed letters painted a single color with the surface wood left natural (clear finish), so I used spraypaint to cover the letter area after routing, without concern for getting pain on the top. Then, when I ran the sign through my planer it got rid of the burrs and paint on the top in one stroke, leaving only the letters (including sidewalls) nicely painted. A spray-coat of poly over the finished product and it was ready to weather the Alaskan winter.
__________________ Check out that new high-tech cordless router.. wireless and no recharging required!! | ||
| | #9 (permalink) | ||
From what I'm gathering from my research, redwood is really pricey. I'd be curious to know the bd ft cost of redwood? I plan on starting out with approximately 2 x 3 foot signs. I read that less costly wood that are good for signs is red cedar and cypress? I'll be doing the first few sigs non-gratis and hope to avoid a 2nd mortgage when buying wood. | ||
| | #10 (permalink) | |||
I recently prices some redwood 2x4's, beautiful stuff, but $3.12 a FOOT. Not much left at my local lumber yard; they said when its gone they probably won't be able to get any more. I remember in the '70's they used to get it by the RR car !! In those days at the local fairs the sign makers had a boatload of 1x6 and 1x8 etc. making signs while you wait !! I've put a little away for carving special trinkets for very special friends. Get it while you can, its like the price of gas, not coming down in your lifetime. Happy sawdusting ! S | |||
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 10 | 08-19-2010 04:01 PM |
| wood residential and business sign routing with | mark disaverio | General Routing | 8 | 07-30-2009 08:53 PM |
| Guidance for making wood signs | rvguy | Sign Making | 3 | 10-10-2007 08:56 AM |
| Router bit burning the wood!!! | rovailla | Router Bits - Types and Usage | 7 | 07-18-2007 02:15 AM |
| Questions about wood Pallets and moisture | GoonMan | Tools and Woodworking | 2 | 07-05-2005 07:11 PM |
