Help
Go Back   Router Forums > General Woodworking > Special Needs Woodworking
For Darrel
This is a discussion on For Darrel within the Special Needs Woodworking forums, part of the General Woodworking category; Darrel, please tell us a bit more about yourself, your amount of vision and mobility. ...
Old 12-11-2008, 10:58 PM   #1 (permalink)
Mike will become famous soon enough
Default For Darrel
Report Post Report This Post!
Darrel, please tell us a bit more about yourself, your amount of vision and mobility. It would help to know which router model you are using. We will assist you in getting set up to use your router safely. There are many ideas floating around, one of the most useful is marking your guide bushings so they are easy to identify by touch. This can be as simple as a small notch cut in the edge for one size, two notches for the next, etc.
Old 12-12-2008, 09:47 AM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Darrel
Just one more way
Many of the guides sets come in a plastic case, the sizes are stamped into the plastic case this will make it easy for you to pull out the right one and then put it back it place when your done with it..
But you can always use a center punch and put in the dot system on the guides. and mark the case the same way,by drilling holes in the plastic case.
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
bobj3 is online now
