Help
Go Back   Router Forums > General Woodworking > Starting Off
Craftsman Auto-Scroll Saw
This is a discussion on Craftsman Auto-Scroll Saw within the Starting Off forums, part of the General Woodworking category; I need replacement blades for model no. 315.172321 scroll saw. Sears has been absolutely no ...
Old 06-16-2009, 04:23 PM   #1 (permalink)
lindon is on a distinguished road
Default Craftsman Auto-Scroll Saw
Report Post Report This Post!
I need replacement blades for model no. 315.172321 scroll saw. Sears has been absolutely no help, all they say is they are no longer available. It appears to be the same type blade used by a newer model 315.172321. Does anyone know a source?
lindon is offline
Old 06-16-2009, 05:57 PM   #2 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi lindon
You may want to check the model number,,the one you posted is for a jig saw..
I know they call it a scroll saw but it's jig saw,, HD/Lowes should have one that will fit if not just grind just a little bit..
Or stop by one of the many Sears out lets I'm sure they will have one that fit..
CRAFTSMAN | Model #315172321 | SCROLL SAW | HOUSING | SearsPartsDirect.com
CRAFTSMAN | Model #315172321 | SCROLL SAW | SearsPartsDirect.com
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-16-2009, 10:28 PM   #3 (permalink)
Hey Bob - Me bad, the correct Model No. Is 315.17280, similar to 315.172321 that I was able to download a manual for since I couldn't find a manual for the 315.17280. I was at both of the sites you posted, visited Sears store, called Sears parts, went to Lowes. Nothing at Sears store, no help at Sears parts, Lowes had nothing close. Per the manual picture, the blade has a hole at the shank end that a set screw goes through.
lindon is offline
Old 06-17-2009, 10:58 AM   #4 (permalink)
bobj3's Avatar
Hi lindon
I have many jig saws,,I almost always pick up one the B & D sets ,,I never have the right blades on hand ,,with a pair of vice grips and with a grinder you can make your own easy..the hole for the set screw is not a big deal,the screw will lock the blade into place...
If you want the hole in it just take a prop.torch to that end of the blade and drill one out on the drill press after you drill the hole heat it one more time and stick it some water..
I like the Bosch blades and do this all the time when I need a great blade for hardwood
Part Finder
Bob J.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 10 10-24-2009 06:34 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 11:29 AM
craftsmen router? rhe8542 Starting Off 21 04-20-2009 11:51 PM
Help identify scroll saw & Band saw Kristin D Tools and Woodworking 11 11-29-2007 10:11 PM
Craftsman scroll saw part? Birch Wood Scrolling 6 11-17-2007 03:47 PM
